E4OD Solenoid Question
Old Apr 12, 2009 | 07:47 PM
lincoln20012002's Avatar
lincoln20012002
HI,
I posted this over in the 87-96 section and it was I post here as well.
I have a 92 F150 5.8 E4OD.
I purchased a 95 E4OD as a replacement. My question is do I need to replace the 95-up solenoid block with an 89-94 solenoid block?
The solenoid block on the 95 is bad (fluid in the plug) so it's going to get replaced either way.
Thanks
Old Apr 12, 2009 | 08:40 PM
jk080's Avatar
jk080
Transmission Rebuilder
I have never done that, but I did find some info for you. If I find something else I will forward it to you.
You will have to use the 89-94 block.
The plug is different and wouldn't plug up anyways, I know you can use a 95 and later solenoid block on a 89-94 trans and install it in a 95 and later truck, I am not positive you can use a late trans in a early truck with a early block, but I would think it would work with no problems.
This is a old bulletin, 13 years, so the new solenoid blocks they are referring too, are not that new anymore.....
Name:  E40D Solenoid.JPG
Old Apr 12, 2009 | 09:03 PM
lincoln20012002
Wow thank you!
This old bulletin answered all of my questions and confirmed my hunch that the 95 and up computers are different.
I knew the plugs were different but there is a common myth that that you can re-pin the connector on a 89-94 truck and get it to work with a 95-up solenoid block. This is incorrect.
Thank you again!
Old Apr 25, 2009 | 05:03 AM
f350idi's Avatar
f350idi
E40d solenoids
Hi
I have been down this road before and can say that an early solenoid pack (early conector) will not work in a late solenoid pack case with out modifications. Let me know if you want the details.
cheers
f350idi
