Speedometer cable and gear issues
Old Oct 18, 2014 | 12:18 PM
Tyler S's Avatar
Tyler S
Hey guys,
I've posted on here before about this but I've never really solved this problem. So I'm going back to basics and starting there.
Here's what I've got: 89ish T5 world class tranny with a Chevy tailshaft housing in my 51 F1 (all done according the "ultimate T5 conversion page" or whatever it's called. Anyway, I also have a 2.73 rear axle ratio, so kind of a weird combo with the T5 tranny, but not unheard of. Apparently mustang restorers use T5s and 2.73 rear ends on a fairly regular basis. However, they DON'T need to use the Chevy tailshaft housing (need it in old trucks because of where the shifter comes thru relative to the bench seat).
So, back to the very basics: pictured below is my old speedo cable. It came out of our old/discarded FMX tranny. I've come to the conclusion that this cable end will not work in a Chevy tailshaft housing at all. Am I right? I THINK I need a GM style cable end and a GM driven gear (the gears pictured are identical Ford gears but I cut the end off one trying to make it fit. No luck). Unfortunately I'm not sure I can get a GM gear that will work with my T5 and a 2.73 rear end.
Anybody out there an expert on this?
Thanks!!
Tyler
(And btw, tranny shops and speedo shops have been less than zero help on this).
Old Oct 18, 2014 | 01:02 PM
Muppy1840's Avatar
Muppy1840
I don't know if it will help but try t5cablespeedometer.com. Guy named Dan Conley. He takes t5 electronic transmissions and converts them to cable drive. He had a both set up at the Spokane swap meet in July. I will try and post some picks.
Old Oct 18, 2014 | 01:03 PM
Tyler S's Avatar
Tyler S
Thanks!! T
Old Oct 18, 2014 | 01:25 PM
raytasch's Avatar
raytasch
Believe Nothing
That cable is not like the one in my '49 F4. I have the original cable from my F4 running in a GM 700R4. My cable has the female cap screwed onto the GM tranny, fits like it should. It drives the original speedometer. When I had the transmission built I asked for the smallest drive gear available be installed. Even with the largest driven gear, my speedometer is way fast. I run a GPS to determine speed. So, perhaps what you need is a stock speedometer cable????? Perhaps the 51 is different from the 49?? I don't know but just a thought.
Old Oct 18, 2014 | 01:38 PM
Tyler S's Avatar
Tyler S
Hey Ray, I don't completely understand all of your post. But do you think a stock F1 cable (the tranny end) would fit properly in a GM tailshaft housing? I'm just asking. I have no idea. I'm assuming GM has it's own specific cable end for the transmission and that it's different than Ford's. I'm assuming that because it looks like GM driven gears are a different shape than ford gears.
Anybody?
Thx, Tyler
Old Oct 18, 2014 | 02:19 PM
Tyler S's Avatar
Tyler S
Ray, after rereading your post and poking around the internet, I'm thinking maybe you meant I need a stock GM cable? Is that right? T
Old Oct 18, 2014 | 07:01 PM
raytasch's Avatar
raytasch
Believe Nothing
There is the possibility that some GM and Ford cables were the same. I am using a stock original 1949 F4 cable and it connects to the original Ford speedometer head and to the 700R4 GM transmission. It works, works smoothly but the drive gears in the transmission are not right for the original Ford speedometer. The speedometer indicates about ten MPH fast and the error is not liniar. Sorry for the confusing post earlier.
I am working with the 700R4 and you have the T5 so there may be differences there.
Old Oct 18, 2014 | 08:29 PM
tinman52's Avatar
tinman52
Welder User
Tyler, I think what you need is the speedo gear housing. The plastic gear fits in this to drive the cable. The cable end threads onto this housing. A stock F-1 cable should work as Ray said.
Here's a housing.....
T5 Transmissions
Old Oct 18, 2014 | 09:39 PM
Tyler S's Avatar
Tyler S
Originally Posted by tinman52
Tyler, I think what you need is the speedo gear housing. The plastic gear fits in this to drive the cable. The cable end threads onto this housing. A stock F-1 cable should work as Ray said. Here's a housing..... T5 Transmissions
Thanks Scott! So would I need a ford style gear or would only GM gears work with the housing? T
Old Oct 18, 2014 | 10:40 PM
tinman52's Avatar
tinman52
Welder User
You need a T5 gear. Is your trans from a Ford or GM? They are likely the same anyway, but the speedo gear needs to match the one on the tailshaft.
Old Oct 18, 2014 | 11:08 PM
Tyler S's Avatar
Tyler S
My tailshaft is a GM. Forward of that is from a mustang. So I'll need the GM gear. Got it. Thx!
Steve49841
Apr 1, 2015 06:25 AM
Missin'A Gear
Mar 23, 2015 07:03 PM
tasdad
Jan 12, 2006 10:03 AM
cjfaber
Jan 7, 2006 08:07 PM
JRguy
Nov 23, 2004 02:43 AM
