Sponsored by: Real Truck
05+ grille removal
Old Apr 23, 2009 | 07:56 PM
FX4 5.4's Avatar
FX4 5.4
05+ grille removal
how do you remove the bottom hinges on the 05-07 grille? when i took off the 4 top bolts i saw that the bottom was attached by some type of hinges and i was in a rush and didn't solve it yet, so does anyone know?
Old Apr 23, 2009 | 09:03 PM
nghtrgr's Avatar
nghtrgr
Take a long screwdriver and push down on the clips. Start on one side go to the other and it pops right off.
Old Apr 23, 2009 | 09:05 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
what he said. its like 5 clips that hold the bottom on.
Old Apr 23, 2009 | 09:58 PM
FX4 5.4's Avatar
FX4 5.4
do they go back on just as easily?
Old Apr 23, 2009 | 09:59 PM
nghtrgr's Avatar
nghtrgr
Yep Just start on one side, push'em in and put the top bolts back on
Old Apr 23, 2009 | 10:11 PM
FX4 5.4's Avatar
FX4 5.4
awesome. thanks for the help
Old Apr 24, 2009 | 07:39 AM
Downriver Thunder's Avatar
Downriver Thunder
Where do you pop them loose, from under the hood or between the bumper and grill on the outside?
Old Apr 24, 2009 | 08:17 AM
nghtrgr's Avatar
nghtrgr
After you take out the top 4 bolts pull the grill toward you a few inches, look down between the grill and the coolers and you will see the 5 "clips" on the bottom that hold it on just push down on those with a long screwdriver.
Old Apr 24, 2009 | 09:07 AM
FX4 5.4's Avatar
FX4 5.4
hey nghtrgr, do you know how to get the emblem off?
Old Apr 24, 2009 | 10:00 AM
Downriver Thunder
If I remember right you unscrew the nut off and snap the tabs off.
Old Apr 24, 2009 | 02:58 PM
nghtrgr's Avatar
nghtrgr
Take off the cheap nut and then get a couple of small screw drivers to pry/shim the "arrow head" pieces out so the emblem comes off. I wouldn't snap the tabs off or else all that would be holding the emblem on would be the cheap nut.
LRSTony
Dec 19, 2010 02:00 PM
tlb
21
Feb 15, 2010 04:54 PM
Roamer
May 8, 2009 07:46 PM
Roamer
'80-'86 FAQs (Frequently Asked Questions)
Itch71
Mar 10, 2008 09:44 AM
