Door Hinge Pin Mirror
Old Jun 15, 2004 | 02:02 PM
tlb's Avatar
tlb
Finally put passenger side mirror on my 48F1. I used 1/2"" socket to fit over head of pin and used a 6" "C" clamp to fit over socket and bottom end of pin that protrudes below bottom of hinge. Once bottom of pin was flush with hinge i used a 1/4" door hinge pin removal tool with a flat end. This allowed a flat area to use tool and hammer to pound pin out the rest of the way. The pin removal tool i bought at home depot for 6 bucks. To install new pin all you need to use is the "C" clamp. Only took about a half hour. Be careful not to hit side of door with hammer (speaking from experience) Tape a piece of cardboard to door before you start.
Old Jun 15, 2004 | 02:16 PM
SteV8e's Avatar
SteV8e
I bought one of those mirrors for my 52 F3, but I have not installed it. Do you have one on the driver's side too? I am not sure if I want one or two. Thanks for the tips on the technique.
Old Jun 15, 2004 | 02:25 PM
bhiebert's Avatar
bhiebert
Hi TLB
I've considered installing a pair of those mirrors, but have had two reservations -
First - the ads for the mirrors often state that some hinge material may have to be ground off to make the mirrors fit - did you have to do any grinding?
Second - does the swivel on the mirror head allow you to properly see back down the side of the truck? I bought a set of peep mirrors a few years ago, but the mirror heads had a very limited amount of swivel to them - the passenger side mirror couldn't bend enough to let me see what I was potentially backing into.
Thanks
Brian
Old Jun 15, 2004 | 03:20 PM
SteV8e's Avatar
SteV8e
I have the same concern regarding the grinding. Terry, did you need to grind? I wonder why they suggest grinding the hinge. Given the choice, I would prefer to screw-up the mirror rather than my door.
Old Jun 16, 2004 | 05:10 AM
tlb's Avatar
tlb
I did not have to grind the door hinge but i did grind a small taper on the end of the pin to allow pin to fit into bottom hole of bracket. There is enough adjustment in the mirror head but the diameter is to small to have a real good view rearward. I bought the mirror from Bob Drake Reproductions.
I do have a mirror on both sides. I does help backing out of gararge.
Old Feb 3, 2010 | 01:12 PM
Doraville's Avatar
Doraville
I've got a set of the hinge-mounted mirrors that I'm looking to install, and i can't see any possible way to install them without grinding off part of the hinger. I don't believe that I'll have to grind enough to weaken the hinge, but it will be visible. Fortunately, we're doing this before the paint, otherwise I would be a little upset about doing it.
Old Feb 3, 2010 | 02:32 PM
Rusty_Bits's Avatar
Rusty_Bits
I put hinge pin mounted mirrors on my old 1952 F-1 and had to grind a lot off of the hinge; as mentioned above not enough to weaken it but you definitely want to do it in the mock up state.
Old Feb 3, 2010 | 06:40 PM
HD74's Avatar
HD74
My truck was already painted when I got it and the hinge mirror came with the truck so I was bound and determined to install it. Definite some grinding is needed, but like others have said use protection everywhere possible if your grinding.
Old Feb 3, 2010 | 07:18 PM
52 Merc's Avatar
52 Merc
All this hinge grinding you guys are talking about; is this with using aftermarket brackets, or original, OEM parts?
Old Feb 3, 2010 | 08:23 PM
Julies Cool F1's Avatar
Julies Cool F1
I installed the hinge pin mirrors and didn't need to grind anything. I did have to sand off the 10 or so coats of old paint and primer - buity it was all loose, rusty and flaking off anyway.
One thing I did have to do was drill a small recess in the hinge to allow the set screw some place to bite - very small - like a dimple.
Otherwise the thing would creep backwards from wind blast while I was driving, no matter how solidly I tightened the set screws.
Old Feb 3, 2010 | 08:25 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
i put some on my 50 a few years back. At the time i strugled to and finaly got the old pins out with a long punch and a hammer, not to bad. i just bought a door pin remover from Mac's because im going to have to pull both doors to repair rusted door bottoms. i did not need to grind and the mirrors work well in my opinion.
Old Feb 4, 2010 | 05:51 AM
Doraville's Avatar
Doraville
The mirrors I bought look like this:
There must be two types of mirrors out there, one with slightly larger brackets that don't require grinding. Do those of you who didn't have to grind remember where you bought your mirrors? They all look exactly alike in the photos.
-DV
Old Feb 4, 2010 | 06:32 AM
Big IV's Avatar
Big IV
-DV
Looks like the 70s after market motorcycle mirrors. I wonder if they would work...
Old Feb 6, 2010 | 06:56 PM
Doraville's Avatar
Doraville
I just spent about an hour shopping around at the various early Ford parts houses for hinge pin mount side mirrors that do not require that the hinge be ground down. The mirrors that I have came from LMC, and there is no mention of grinding the hinges in the LMC catalog, but I can confirm that they will not work without grinding down the hinge.
Here is what I found at the other suppliers:
C&G - Has a note that the hinge requires modification
Classic Haulers - Has a note about grinding the hinge
Dennis Carpenter - Has a note about grinding the hinge
Sacramento Vintage Ford - Has a note about grinding the hinge
Mid-Fifty - Doesn't appear to carry this type of mirror
F100 Central - No photo... can't tell if they carry it
MAC's Antique Auto Parts - No mention of modifying the hinge
Early Ford Store - Specifically states that this mirror will not work on a pickup
Blue Oval - No mention of modifying the hinge
Bob Drake reproductions - No mention of modifying the hinge
-DV
Old Feb 6, 2010 | 07:27 PM
tlb's Avatar
tlb
I put the passenger side mirror on almost 5 years ago but still remember i did not have to do any grinding of the hinge.
Terry
