I fabbed my own spring pin latches because I am cheap....lol. I couldn't see dropping the bucks for ready made ones when I could whup them up on my own
Bobby
I didn't fab mine cause I don't have the tools, (or most of that skill)..
For rail top latches, I like yours a lot more.. they fill in the rail top, which the aftermarket latches don't..
I did have to extract a small piece of chain ear that was left in the rail top as part of the manufacturing process to use even the small latches.. (which I suspect is why they are small diameter).. and then had to repair the hole left in the outside face of the tailgate.
funny you say that, every time i wash it i have to take a big towel and soak up the water in the bed haha. most drains out but there always seems to keep a pool towards the cab.
For a few years seatbelt style latches were popular on tailgates. They would allow you to just close the gate.
Sit back, sip a few frosties and let the ideas roll around, I'm sure you will come up with something cool.
Bobby
Bobby, you're the man. I had forgotten about the seatbelt latches. Quick trip to the salvage yard, some welding, drilled and tapped a few holes and now a latching tailgate.
It latches easily and I set it up with some adjustment to align the outside of the tailgate to the bed. I'll dress it up a little with some polished stainless bolts and nuts and it'll be good to go. I couldn't believe how smooth the latching action is when closing the tailgate.
that is cool as hell. i've never seen that before.
I had seen it years ago, but until Bobby reminded me I had forgotten about it. Just what I was looking for..... something simple and easy but very effective.
like the seat latches, will they resist weather ? Or rust over time. I havent come up with a solution to hold tailgate in the open position, leaning towards cables but the rubbin' factor will probably play hell with the paint.
I used some plastic-coated cable restraints that I made up. But my bed has Herculiner, so I wasn't worried about scratching paint.
The most foolproof way I have seen of restraining the gate and not messing up the paint is the folding chromed sheet metal supports that look like card table leg supports. Mid Fifty has them. See page 119 in their 2008 catalog. "Show Quality" for $69.95/pair.
Tom
I looked at a lot of vehicles in the salvage yard, many of which didn't have doors or windshields, and the only weather related problems that I noticed was some pitting of the chrome. The buckle portion seems to hold up well. This style of buckle appears to have been used by Ford from the late 70's up through the 80's.
Someone suggested using a gas cylinder like used on the hatch of many SUV's to hold the tailgate in the open position. I'm going to look into that and see if it has possibilities. If not I'll probably use the folding strap type like used in some boat hatches. I'm fairly sure they can be gotten in stainless, which would be one less problem with rust.
I thought I would revisit this thread again to show what I finally came up with on the tailgate supports.
I did a little redneck engineering on a folding support. I used some thin strips of oak to mock-up the folding straps and bent up some stainless mounts for the straps on the bedsides and tailgate.
After getting the action worked out, I cut my support straps from some scrap stainless in the metal pile and after some polishing and a quick trip to my local TSC for some stainless bolts and lock nuts..........
