C6 Kickdown switch using a 4bbl Holley
Old Oct 28, 2002 | 07:47 PM
GeneStoner's Avatar
GeneStoner
C6 trans mated to an 300cid inline 6...
what to use for the kickdown switch when also using a 4bbl Holley?
Old Oct 28, 2002 | 08:30 PM
Schwee's Avatar
Schwee
yo,,,
i have a 650 on a 351,,,, runs good,,, sure, use it, unless its screwing up other stuff.....
good luck
Old Oct 29, 2002 | 02:28 PM
GeneStoner's Avatar
GeneStoner
Rephrasing my question:
How do you get your C6 to "kickdown" for passing when using an aftermarket carb?
Old Oct 29, 2002 | 03:22 PM
teschwab's Avatar
teschwab
you need to specify a holley with a ford kick down. this linkage is part of the bell crank and will attach directly with the kick down rod attached to the trans. now if you have a new holley and the carb is not a model with the kick down you need to exchange it.
Old Oct 31, 2002 | 09:45 AM
glenb's Avatar
glenb
if your holley is not set up for kit down, you can get a
little holley kit that will let you have a kickdown linkage on
it. i added one and worked fine.
glen bransfield
houston tx
Old Nov 7, 2002 | 12:26 AM
whizbang's Avatar
whizbang
lokar makes a very nice kit to put a kickdown cable on a c6.
i've got one on my 460 with a holley 750 double pump and it works great.
Old Nov 7, 2002 | 12:55 AM
Ford_Six's Avatar
Ford_Six
The 1BBL linkage won't work with an aftermarket intake. The best thing to do is to rig a cable setup (pretty easy really), or shift manually. With the 300's torque you should be able to run it in drive around town, and if you need to pass, just hit it to L2. Just remember, the C6 has a manual valve body. If you put it in 2, it's in 2. It won't upshift out of L1 on its own. And if you're cruising, and hit it to L1, it will go there.
Jared
Old Nov 7, 2002 | 07:11 AM
big_red_79's Avatar
big_red_79
dutchlincoln79
Jan 25, 2008 01:18 PM
klatt_89
Jun 20, 2006 12:32 PM
BigBear1
Jan 10, 2006 07:54 PM
msb71
Jan 26, 2005 03:00 AM
GeneStoner
Sep 26, 2003 01:00 PM
