98 studdering possible vacuum leak
Old Apr 22, 2009 | 08:04 PM
jimmah's Avatar
jimmah
Hi, I have a 98Expy with the 5.4L. I recently replaced some vacuum lines because it was causing the truck to stall and idle rough. Everything was great but now about 2 weeks later it is doing it again. I climbed under the hood and rechecked everything. Looks good. Check engine light is on but I haven;t had a chance to scan it yet. While under the hood I took off the cover to the throttle body and revved it so I could listen. When it first starts to rev it sounds like the engine is sucking air in the rear of the engine on the passenger side. I tried the aerosol trick to no avail. Is there any vacuums in the region that are hard to get to or know to be trouble some?
Old Apr 22, 2009 | 10:04 PM
alloro's Avatar
alloro
There is an elbow back there for the PCV system that tends to crack.
Old Apr 22, 2009 | 11:39 PM
jwitter's Avatar
jwitter
If the codes are the lean codes then I went through the same thing with mine. I replaced the vac lines and elbow - they were cracked but not leaking and also changed the fuel filter. It was better for awhile then started again while on the road. Long story short - the road mechanic tested the MAF sensor and it passed, then I brought it home to my regular mechanic and he tested it with 2 different systems and it passed. After trying various things he took my truck to Ford and tested it there and the MAF failed. After a new one was put in it ran like new.
If you have a friend with the same motor or MAF sensor I would swap it out and try it just to be sure.
Old Apr 23, 2009 | 04:23 AM
jimmah's Avatar
jimmah
I actually have a 98 4.6 expy also, I would assume the MAF is not the same though right? Now the PCV valve where is that located? I've never had to change one.
ydaveitsu
158
Jan 10, 2023 05:10 AM
subford
29
Jul 4, 2016 06:11 PM
regidog
Mar 1, 2016 06:59 PM
Michael9280
1997 - 2003 F150
Apr 28, 2014 11:15 AM
sfort
1978 - 1996 Big Bronco
Mar 15, 2011 09:26 AM
