vacuum pump or booster???
Old Feb 26, 2016 | 08:18 PM
regidog's Avatar
regidog
Replaced both the vacuum pump and booster last February 2015. Maybe put 3ooo miles on the truck since then. No problems with brakes until it got very cold (0 degrees) 3 weeks ago. Went to start the truck and there was no assist to the brakes. Pedal was hard and truck hard to stop. Hooked up a vacuum gauge at the vacuum manifold last weekend (50 degrees out). Vacuum was 24 inches of Hg, hit brakes, gauge would go down to 15-17 inches of Hg, let off backs it would go back up to 24. When pedal was held down the vacuum would hold.
Today I installed a vacuum gauge on the dash (for some sense of security). Started truck and gauge read 24 inches of hg, hit brakes went back to 15-17 inches of hg. Did this several times no issues. Figured everything was good. Held brakes down and watched the gauge slowly drop to 5 inches. Let off brakes and the vacuum never returned to 24 inches. Couldnt get the vacuum to go back up. Looked under hood and did not hear any leaks. Weather is 35 degrees out. i cant determine if its the pump or booster. Any advice? Thanks
Old Feb 27, 2016 | 03:36 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Sounds like pump to me. Odd that its intermittent like that
Old Feb 27, 2016 | 08:30 AM
tjc transport's Avatar
tjc transport
i ain't rite
i agree. if it was the booster, it would either recover as soon as the brakes were released, or it would never create any boost at all when the booster was connected.
Old Feb 27, 2016 | 08:00 PM
regidog's Avatar
regidog
Thanks fellas. Vacuum pump is still on warranty so will exchange it out and see what happens.
Old Feb 27, 2016 | 11:45 PM
hairyboxnoogle
Before jumping to any further conclusions, you need to run a hose from the pump to gauge, unplug it and replug it a few times, or at least take the booster out of the equation.
Old Feb 29, 2016 | 07:46 PM
regidog's Avatar
regidog
Pulled the pump and once I got the pulley off I noticed oil on the bearing face and back of pulley. Think I found my problem.
Old Mar 1, 2016 | 06:59 PM
hairyboxnoogle
Put a new one on the boss' psd a while back, went 6mos and popped the back bearing cover off. Forgot about it.
moroza
Jul 2, 2019 12:59 AM
Duckkiller72
Oct 26, 2015 12:40 PM
KCalvin
16
Nov 9, 2010 09:00 AM
912504x4
Nov 29, 2006 09:41 PM
