Looking for a jack point
Old Apr 22, 2009 | 06:55 PM
eigenvector's Avatar
eigenvector
I will be overhauling the front-end on my 2000 Ranger 2wd and need ideas for where to put the jack stands. The Ranger has two jack points on the front, but they don't fit jackstands (too small). The cross-member is too wide and I guess makes me wonder about slippage. Obviously using the steering arms isn't an option. Another thing I notice about the Ranger is that the jack points are really high up there - which makes the jackstands have to reach for it (and wobbly).
So where do you put jackstands when you want to do extensive work on the front end of the truck? Is the frame cross-member the only option?
To give you an idea of the scope, I need to have the rotors turned - so while I have them off I figured I'd replace the tie-rod ends, lower ball joints, and possibly the upper tie-rods.
Old Apr 22, 2009 | 07:27 PM
Rangerman Stan's Avatar
Rangerman Stan
I know what you're saying about the jack stand being too narrow. I've got a couple of different types and capacity stands to work with which helps let me put the support where it's needed. My 3.5 ton stands have a wide cradle that lets them go on the frame where ever needed. See if the main part of your frame narrows down up in front close to the bumper. Maybe your stands will fit more securely in that area.
Old Apr 22, 2009 | 08:15 PM
Fordteamone's Avatar
Fordteamone
Not sure about the two wheel drive or if this will help but we just put a clutch, slave cyl and redid the CV seals on the front of a friend’s 2003 4X4 Ranger and supported the front on the two protrusions sticking out in front of the front suspension.
Old Apr 22, 2009 | 10:45 PM
eigenvector
Well that's not much encouragement. I guess I haven't looked forward of the front suspension, hadn't thought of that. Once the weather clears I'll take a look.
For now this is what I'm looking at
http://photos.imageevent.com/eigenve...anger_tow2.jpg
(ignore the red dots, they were from something else)
Syncrowave
20
Feb 1, 2016 09:40 AM
AVR2
Escape & Escape Hybrid
Jan 14, 2016 07:43 PM
t_dub
Oct 8, 2015 03:22 PM
TJ SD
Feb 16, 2015 11:43 AM
eigenvector
May 7, 2009 08:33 AM
