Sponsored by: Real Truck
BIG Problems need HELP...
Old Apr 22, 2009 | 06:45 PM
Laynlowf250's Avatar
Laynlowf250
I have an 05 f250 which the master was just swapped out to add the factory trailer brake setup to the truck. Since the swap the brakes work fine then decided to start dragging hard. If you crack the lines going to the master cylinder they loosen up and go back to normal after a couple minutes then build pressure in the line and start dragging. Is there just air in lines or ??? Any help would be much appreciated
Old Apr 23, 2009 | 01:19 PM
Wash1331's Avatar
Wash1331
Air would not cause this problem as air compresses and does not allow the brakes to work fully...hydraulic principals. Sounds like you may have a bad master or it is not set properly. You are getting pressure bypassing the valves allowing fluid to build pressure in the brakes during non braking periods. I am assuming that you put in a bigger master due to tow braking. Ensure that the actuation cylinder has the same throw distance that the older one had. If it is longer it will hold the cylinder slightly open allowing the bypass. You may have to install a shim to take up the longer travel. If a dealer installed return and see if they can adjust or replace. Hope this helps.
pacrewchief
Jul 6, 2009 04:59 PM
jarrodfeldt
May 18, 2009 07:21 PM
RacerLT250R
Mar 5, 2008 07:16 AM
brettwingfield
Sep 16, 2007 09:14 PM
fuddy
Aug 26, 2007 02:08 PM
