computer
Old Apr 22, 2009 | 12:10 PM
ktp744's Avatar
ktp744
computer
What is the difference in the computers between auto or manual transmission? Will auto computer work with manual transmission?
Old Apr 22, 2009 | 12:29 PM
Lazy K's Avatar
Lazy K
The auto comp. should be OK with a man. Check out the thread a few lines down this forum page by Ztitan on doing a auto to man. swap.
Old Apr 22, 2009 | 12:55 PM
pc_2000's Avatar
pc_2000
It depends on what kind of automatic you have. The E4OD is computer controlled so the computer for it would not work on a manual.
Need more info though... What truck, year, motor, trans, 2wd 4wd, etc.
Old Apr 22, 2009 | 05:08 PM
EPNCSU2006's Avatar
EPNCSU2006
An E4OD computer will run an engine with a manual transmission, although it will turn on the check engine light because the transmission is missing. A manual transmission computer can't be used with an electronic automatic, but should work with a non-electronic automatic.
mrrish79
Oct 30, 2013 07:46 PM
derherr65
Feb 24, 2006 08:34 PM
bigbluetruck
Jan 23, 2002 01:24 AM
dptywrdn
Bronco II
Jan 12, 2001 06:31 AM
