Truck is all factory.
223 Inline 6.
I'm needing to find out what transmission came factory on this truck?
It has a column shifter, but, it doesn't run.. so, I'm not sure how many
gears it has.
Did the 64 F100 come with only one certain type of Manual tranny?
Thanks, Gumbo!!
I'll also get back with you on that bed deal we talked about in the next couple of weeks.. well, maybe at Pate??
Are you going to Pate this year?
In all likely hood you have the standard ford light duty three speed transmission with a bolt on type yolk. Post the trans code off the warranty plate mounted on your drivers door.
