part numbers?
Old Apr 21, 2009 | 11:12 AM
bmwfreak's Avatar
bmwfreak
part numbers?
looking for NAPA / UAP part numbers for 66 F100 exhaust manifold to downpipe gasket (not the manifold to engine gasket)
high beam floor switch
battery? I know, couldn't I just measure the tray? but I wanted to find out if there was a specific battery first
fuse block number? trying to stay as close to original as possible as I am okay following wiring diagrams but I am not electrical engineer and don't like figuring out some one else's electrical mess; would rather start from scratch
thanks
Old Apr 21, 2009 | 01:48 PM
camperspecial65's Avatar
camperspecial65
the battery trays are a tough find...for a perfect one...and when you do find them they arent the cheapest thing around...6 and 66 each use different battery trays..If you want a pretty good one, but not perfect I have a 66 tray floating around here...as well as the dimmer switch...The exhaust donut gaskets are the easiest thing to find...definately something your local store will have most likely on the shelf.
I dont have the aftermarket part numbers for any of them but the battery tray...which none are available NOS...
- cs65
Old Apr 21, 2009 | 02:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
thanks
NAPA, most other autoparts stores can cross Motorcraft part numbers over to the brands they sell.
COTZ13A024A .. Dimmer Switch (Motorcraft SW263) Fits: ALL 1960/79 cars/trucks, some well into the 1990's.
1965/66 Motorcraft Battery group numbers: R22F = 45 amps / R24F = 55 amps / R27F = 70 amps / R27FA = 80 amps.
The battery group number is what everyone goes by, dealers and autoparts stores alike.
IMO, the 45 and 55 group batteries do not provide enough cold cranking amps, I'd go with either the 70 or 80 amp battery.
NOTE: Make sure the battery's group number has an F suffix.
If the suffix is a G = GM, the battery terminal positions are reversed.
These same batteries were used thru 1996 on F Series trucks / 1975/91 Econolines / 1978/96 Bronco's.
1960/79 cars also used these same batteries, so they are EZ to find.
Where is the fuse panel on your truck? On the firewall or on the headlamp switch?
Is the manifold to inlet pipe gasket donut shaped or flat?
> > > FTE member AirHarley, who posts in this forum, is a NAPA partsman.
Old Apr 21, 2009 | 03:26 PM
bmwfreak's Avatar
bmwfreak
thanks Bill,
the fuse block is mounted to the inner fender and consists of 2 different blocks, which is why I want to find an original block
my battery is present (pretty rusty but probably fixable), will check NAPA for the appropriate battery
exhaust gasket is probably a donut as it looks like it is a pretty big space; the bolts for the flange are long and a flat gasket would not allow the nuts to be tightened enough to make a good connection
Robert
and holy crap, does the fender really need 18 or more bolts to hold it on!!! have broken 8 of them so far trying to remove them, soaking in WD40 for days, really dislike those allen head bolts, going to change to regular head bolts and invest in a large vat of anti-seize compound!
Old Apr 21, 2009 | 03:29 PM
bmwfreak's Avatar
bmwfreak
it is funny you say the batteries were the same from 60 to 79
the local Cdn Tire could not find a 66 in their system so I said give me a '71 battery (was in their system) but the battery is taller than I expected and not as long; leaves about 4 inches at the end of the tray
anyone have a physical size on the battery?
thanks
Old Apr 21, 2009 | 05:04 PM
NumberDummy
thanks
Having owned a 1965 F100 (still do), 1968 F250, 1971 F100, 1976 F250, 1979 F150, 1988 F150, 1992 F150, 2004 F150 and the fact that I have the parts catalogs...I know what batteries were used in these trucks.
Every one of these trucks (except the 2004) had either an R27F or R27FA in them.
What group numbered battery did you buy?
It's not one of the ones I listed above, it's prolly a replacement battery used in one of the 1980/90's cars like an R35F.
R22F: 6 13/16" (W) / 9 27/64" (L) / 8 5/16" (H)
R24F: 6 13/16" (W) / 10 3/4" (L) / 8 5/16" (H)
R27F & R27FA: 6 13/16" (W) / 12" (L) / 9 3/32" (H)
W = Width / L = Length at top / H = Height.
As original: There's no such thing as a fuse box mounted on the fender apron.
There is only one, it's either mounted on the firewall inside the cab (C6TZ14A068E), or plugged into the headlight switch (C4TZ11A647A).
What color are those blocks...white? If so those are ballast resistors someone added...because the only resistor on these trucks is a wire:
COLF12250A .. Resistor Wire-Ignition Coil / 61.50 " long, color colded PINK.
Old Apr 21, 2009 | 11:37 PM
modeleh's Avatar
modeleh
"Crappy Tire" or "Cambodian Tire" has one of the most antiquated parts systems in the universe. They still use amber screen computer monitors from the 1980s. The last time I was in my local store I laughed at the guy's computer and asked him when are they going to upgrade. He said they are having a hard time finding amber screen monitors now. No S**t!
When you go there looking for a master cylinder, the first thing they ask is what size engine does it have? Their system doesn't allow them to look up any part unless they type in what engine the vehicle has. I'm just amazed they don't ask for the color of the car. Even though their prices are sometimes alright, dealing with the counterpeople and their system can be draining.
Old Apr 22, 2009 | 05:06 AM
jowilker's Avatar
jowilker
thanks
Why do you care? Find one with the CCA that you want or need with the posts on the ends that you need, that will fit in your tray, and stick it in the truck, close the hood and start driving.
John
rebocardo
26
Jan 5, 2016 09:25 AM
Blue 55
Oct 4, 2015 02:24 PM
Ford Fx4
Oct 2, 2012 06:57 PM
Andresito
Feb 16, 2005 12:20 AM
1977_250_460_C6
Dec 2, 2004 08:54 PM
