Sponsored by: Real Truck
5.4 tapping noise......???????
Old Apr 23, 2009 | 08:01 PM
dkf's Avatar
dkf
Sounds like a classic exhaust leak at the manifold. The studs will sometimes stay rusted fast even after they break or the manifold could be warped. Just heard a ticking 5.4l at wally world, guess I should have told the kid to get it fixed. Lots of guys running around with annoying exhaust leaks, not just Fords either.
Old Apr 23, 2009 | 08:36 PM
jimvh2's Avatar
jimvh2
Does it sound like it's seriously low on oil?
There is a issue with the 5.4's. The cam phaser assy in the front of the motor gets noisy at about 40K. I had mine done under warranty at about 92K, I'm now at 126K and it's starting to come back.
check this TSB - https://www.ford-trucks.com/tsb/full...php?tsb=06-4-7
OOOPS my bad - I didn't notice that you have an 02. I'm sure this is only on the 5.4 3 valves.
Old Apr 24, 2009 | 03:21 AM
2002 F-250's Avatar
2002 F-250
2002 f-250
Had same problem drove me nuts for a year I had everything checked and it turned out to be passenger side excust manifold gasket.They are very thin and after replacement it cured the nose.I had mine done so it cost me about $350.00 mostly labor.
Still Smoking
2004 - 2008 F150
Nov 10, 2012 03:07 AM
Contingen-Sea
Sep 6, 2011 02:24 PM
jnye6625
Mar 14, 2007 10:08 AM
Boidster
Modular V8 (4.6L, 5.4L)
Feb 9, 2007 07:29 PM
ceetwarrior
42
Jun 27, 2005 05:48 PM
