what will fit?
Old Apr 20, 2009 | 10:38 AM
holyjebus's Avatar
holyjebus
Exclamation what will fit?
I have a 71 F-100 with a 460 engine and c6 trans.
Im looking to downgrade the engine for economy. what will fit the c6? I was thinking something EFI
I am willing to trade the 460 for a new or rebuilt EFI engine (that will fit and work)
Old Apr 20, 2009 | 10:55 AM
Redcat Diesel's Avatar
Redcat Diesel
Hi and welcome to FTE. Your other engine choices if you chose to keep your existing C6 are 351M, 400 and 429 none of which are noted for good fuel mileage. What you might consider is a 302 or 351W. Both are good engines and EFI versions are common. You may be able to find a parts truck with a good engine/C6 combo. Another choice would be a 300 EFI 6 cyl. They are gutsy and seem to run forever. Another note you may find helpful is 300, 302 and 351W all shared the same bellhousing bolt pattern. All of these engines are also pretty much bolt in swaps.
Old Apr 20, 2009 | 11:30 AM
jowilker's Avatar
jowilker
You will come out just as good buying another gas sipper vehicle and keep the ol truck to have fun with. You can do the swap but will have more money invested than if you bought another car/truck as a daily. IMHO
John
Old Apr 20, 2009 | 12:23 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I Agree with Jo Wilker here.
However if you are wanting to go the route of changing engines.
I'd go with a Non Feedback Carbed 300-I6 from the early 80's. Why I say carbed, is that they have a higher Gas mileage rating with the EPA than the EFI version.
EPA MPG rating.
21 MPG Carbed 300
18 MPG EFI 300
Don't forget however that the transmission, tires, and rear end ratio also factors into mileage. Also the Bumpside is quite heavy compared to it's 80's and 90's counterparts.
Old Apr 20, 2009 | 06:49 PM
holyjebus's Avatar
holyjebus
hey thanks for all the suggestions!
from what I gather just about any engine going with the c6 drinks gas like nobodies business...
soooo..
what about a complete engine and tranny swap? maybe from a newer vehicle. I was thinking the 4.0 SOHC from a 97 explorer. thats what I drive and I have had no major problems with it at over 240,000 miles.
would that be a good or bad idea and why?
what would be the best combo for good mileage?
as for investing is a more fuel efficient truck... I have an explorer that gets around 23 highway and 16 city.
I just want to drive my truck but cant afford the 15 dollars a day for gas
on the other hand junkyards around here are pretty cheap. so I could pick up a decent rebuilt pair for around 2k and sell the stuff I have now.
about how much is a running 460 and c6 worth can anyone put a ballpark figure on it?
Old Apr 21, 2009 | 04:07 AM
jowilker's Avatar
jowilker
Hard to say, maybe $200-600.00. These old bricks will not get mpgs like newer ones.
John
Old Apr 21, 2009 | 01:11 PM
mcdobson's Avatar
mcdobson
Like John said, these old trucks are old heavy bricks. Although the 4.0 hp ratings look like it should work, it does not have the torque to do it.
Find a donor truck with 460 fuel injection and overdrive trans, You won't get that much improvement but probably as much as any of the other options.
Old Apr 21, 2009 | 04:05 PM
Virto's Avatar
Virto
A few people will tell you, the key to MPG in these trucks is OVERDRIVE!
Either look to swap in an engine with an AOD or other 4-speed OD transmission, or look into an expensive aftermarket overdrive.
There's a lot of work in swapping some engines, especially when swapping to a small block or an I-6. Those 300s will never let you down, though.
Personally, I'd do nothing. I'd be happy with double digits but expect less.
Old Apr 21, 2009 | 05:00 PM
jowilker's Avatar
jowilker
Good point Virto, I agree, OD is the a good answer, however the OP didn't ask about that.
John
Old Apr 22, 2009 | 08:33 PM
Bart8109's Avatar
Bart8109
I rebuilt my 390 and put a 700R4 behind it. The engine is just getting broken in and on my last trip I got +17 at 75 mph. I'm very happy, plus it's about 345 hp. However, as has been pointed out for what I spent I could have gotten a good used civic or focus. But, since I want to drive my truck, I'd look for a 5.0 HO with AOD in the 87-92 year range and swap it in. I've looked on Craig's list and seen many prospects, so it can be done for much less than I spent. Won't have the horses, but it'll get good mileage (for one of our trucks).
Just my .02.
Old Apr 22, 2009 | 08:41 PM
marks69's Avatar
marks69
i have the 302 ho and aod on mine. alot better on gas. used to spend $33 a day to go to work and back, now down to 11.
that's canadian, so about $1.50 for you south of the border.lol
it wasn't too bad to put in, just need to find someone who know's what their doing if you go to a shop. i went lokar kickdown, and a floor shift so after you get the driveshaft shortened you just need to adjust the cable.
makes a world of difference, just not real good at accelerating up hills on the highway.
