Question for Number Dummy...
Old Apr 19, 2009 | 06:51 PM
redstarr1000's Avatar
redstarr1000
I have a 65' standard cab F100 and trying to find a NOS round type speedometer. Can you help Number Dummy?
Old Apr 19, 2009 | 07:14 PM
camperspecial65's Avatar
camperspecial65
Theres 5 available...5 different sources, closet one to Ca is Bob Allen Ford in Overland Park, Ks their number is 913-381-3000
JST which is in Tn, their number is 615-443-3086 and Miller Obsolete in NY state, their number is 800-546-7278...DC has one too...but Ive seen these same LOOKING speedos posted in their catalog...but in KM...NOT mles per hour...theres also one at an outfit in Puerto Rico...
The p/n is C1TZ17255E
- cs65
Old Apr 20, 2009 | 12:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/66 F100/1100 Round Speedometer / 1966/74 Bronco
Welcome to FTE
C1TZ17255E .. Speedometer-Round Head
Fits: 1961/64 F100/1100 Standard/Custom Cabs / 1965/66 F100/1100 Standard Cab / 1965/66 F100/250 4WD Standard/Custom Cab / 1966/74 Bronco.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 800-546-7278.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
DENNIS CARPENTER OBSOLETE PARTS in Concord NC has ONE = 704-786-8139.
ALCALDE AUTO PARTS in San Juan Puerto Rico has ONE = 787-753-1845.
BOB ALLEN FORD in Overland Park KS has ONE: 800-676-0675 / This dealer thinks their obsolete parts are GOLD. Try them last.
btw: What is wrong with your old speedo? If it does not work, that could be caused by a stripped speedometer gear in the transmission, or a broken cable.
There are two different gears. One on the output shaft (DRIVE gear), one on the end of the cable (DRIVEN gear).
The usual gear that strips is the plastic DRIVEN gear. Still available from Ford...there are 6 different tooth counts...the most expensive gear is $3.47.
Inside the speedometer cable's housing is a woven steel core...it could have snapped in two.
You can buy a replacement speedo core from a parts store, cut it to fit, install in the housing.
Make sure to lube it with either graphite or white lithium grease (light coat).
The reason the core snaps...is...it dries out, then binds up in the housing.
GeneGregory
18
Nov 11, 2016 08:40 PM
Red69
Jul 6, 2016 07:52 AM
Gramps67highboy
Apr 14, 2016 01:40 PM
abe
Jan 3, 2016 09:26 AM
Cazman1955
Dec 8, 2015 01:29 PM
