differential identification
Old Nov 21, 2002 | 12:27 PM
kenpoore's Avatar
kenpoore
I am trying to find specifications and parts for a differential. the tag top row is S319D and the bottom row is 3L5095A24. It has 3.50 gear and 31 spline. Any info would be helpful.
Old Nov 21, 2002 | 07:15 PM
cek181's Avatar
cek181
from the bottom row you can read 3.50 limited slip, that's all i know about the code. what year and model truck do you have and what kind of information are you looking for?
chris
Old Nov 22, 2002 | 09:39 PM
kenpoore's Avatar
kenpoore
Thanks for the reply Chris. I was trying to ID the differential to get repair parts. I needed the carrier (the part the ring gear is attached to. Finally found one ($$$!). This differential is a limited slip version with 4 pinion gears driving the axles. probably would have been cheaper to buy a good used limited slip or traction lock differential. The differential is in a 1985 Bronco. this is not the original differential. The previous owner installed this after replacing the original engine with a 1970 429 with a holly 4 barrel and MSD ignition. Thanks again for your reply.
Old Nov 23, 2002 | 09:57 PM
gearman's Avatar
gearman
Looks to me like a 9" Ford 3.50 ratio with a trac-loc carrier (unless someone has changed ratio or carrier).
Parts availability for the 9" are endless in the aftermarket world. I installed a Auburn Pro series carrier in my 1979 F-150 about eight years ago when I rebuilt it.
There are many different combinations on axle bearings for the 9". Be cautious when ordering new ones. The later model in trucks commonly used the taper cone & cup style (BCA# A20 & National seal# 3195).
Also, many different pinion yokes. You will need all the numbers off of the tag if you are trying to order a new yoke thre Ford. Some of the yokes have been obsoleted; however, find one that is the same height & utilize a different conversion u-joint @ the diff.
Old Nov 23, 2002 | 10:04 PM
cbwarrior's Avatar
cbwarrior
Post differential identification
TheBludgeon
May 27, 2011 05:08 PM
cmachk
May 3, 2007 07:05 PM
BottomFeeder
May 13, 2006 10:14 PM
ALL BOY
Jan 8, 2006 04:39 PM
jluttrell
Sep 13, 2004 02:06 PM
