Sponsored by: Real Truck
power steering pump noise
Old Apr 19, 2009 | 06:31 AM
Diesel Smoker's Avatar
Diesel Smoker
Anyone have any problems with power steering pump making noise while turning.Fluid level is good truck is 03 with 70,000 miles only makes noise when turning.
Old Apr 19, 2009 | 07:15 AM
chevypc's Avatar
chevypc
My 2002 F250 has done this since it was new. I have never had a problem, other than the noise.
Old Apr 19, 2009 | 08:58 AM
aldridgec's Avatar
aldridgec
Who doesn't. Fords are bad for noisy power steering pumps on almost any vehicle. I thought the ones on the 6.0s were better. Might just be time to change out the fluid. that can help alot.
Old Apr 19, 2009 | 09:15 AM
LMS Residential's Avatar
LMS Residential
same here, 08 SD250, noisy since dealer lot, worse when cold. works fine just annoying. Service tech described as normal condition, its a heavy duty truck. ???dont know if BS but seems to work fine and fluid level ok.
Old Apr 19, 2009 | 09:21 AM
newgeek's Avatar
newgeek
i have read some swap out the old fluid for synthetic atf and it seems to do the trick but you will have to search out the spacifics.
Tanner2255
Sep 30, 2012 06:41 AM
trevstaff
Feb 25, 2012 07:25 PM
zorro
May 31, 2006 03:58 PM
mcmklm3
Nov 24, 2003 10:29 AM
