hard fuel lines vs flex lines
Old Apr 19, 2009 | 01:12 AM
LCAM-01XA's Avatar
LCAM-01XA
Originally Posted by AndysFords
I always go to a parts house and buy Trannsmission cooler line, it is rated for around 200 psi, it looks the same as rubber fuel line but it is a lot tougher.
Same here, diesel is much closer to ATF than it is to gasoline, especially considering all the stuff other than clean diesel that goes in my tanks Joe, no dangers of a fireball, my buddy's truck has been like that since he got it - as long as you still got the bottom piece of the steel line attached to IP cause that's where all the heat is, not up by the filter head.
Old Apr 19, 2009 | 03:53 AM
pmelah's Avatar
pmelah
joe you would have to worry about the fuel hurting the line before the heat it will work just fine just have to change it out more often than metal and does not look as good as metal
Old Apr 19, 2009 | 08:50 AM
galute's Avatar
galute
I would worry more about just clamping the rubber over the cut off steel line more than anything else. That's a sloppy way to make a connection and a good place for a leak. Works for a temporary fix but not good for a permanant fix.
Old Apr 19, 2009 | 12:35 PM
LCAM-01XA's Avatar
LCAM-01XA
For clamping the hose on the line you use fuel-injection clamps (and not worm-drives) and double them up on the side of the steel line. You can also put a small flare on the steel line's end.
Old Apr 19, 2009 | 12:39 PM
joe f350's Avatar
joe f350
i bought a pice of metal line and am going that that
joe f350's Avatar
joe f350
mlsc i dint know u drove a chevy
Old Apr 19, 2009 | 12:55 PM
LCAM-01XA's Avatar
LCAM-01XA
lol, have you ever heard of a GM vehicle with an XLT Lariat trim? And yes, I did drive a Chev, a '79 c10 stepside with a 350 in it, fun little truck - could burn the tires all the way to 3rd gear, and still got 20mpg on the freeway.
Old Apr 19, 2009 | 01:01 PM
joe f350's Avatar
joe f350
what about ur redneck convertable
Old Apr 19, 2009 | 01:22 PM
LCAM-01XA's Avatar
LCAM-01XA
lol, what about it? It ain't got no rubber to steel fuel lines, tis all high-pressure fuel injection stuff.
Old Apr 19, 2009 | 01:24 PM
joe f350's Avatar
joe f350
i could find ur gallery
Old Apr 19, 2009 | 06:23 PM
LCAM-01XA's Avatar
LCAM-01XA
Uhm, what?
Old Apr 19, 2009 | 07:24 PM
joe f350's Avatar
joe f350
ur profile gallery
Old Apr 19, 2009 | 11:34 PM
  #28
LCAM-01XA's Avatar
LCAM-01XA
What about it man?
Old Apr 20, 2009 | 12:24 AM
  #29
joe f350's Avatar
joe f350
ita says u havent made one yet i thought u did
Old Apr 20, 2009 | 12:38 AM
  #30
starmilt's Avatar
starmilt
Joe what all do I need to put pictures on my computer. I have a digital camera what else do I need.
