86 7.5L - Cold Start
Old Apr 18, 2009 | 08:30 AM
E30tdf's Avatar
E30tdf
I have a cold start issue that I don't have a solution for. It does not seem to be the choke setting as I have tried several choke positions. Runs fine after warm up. I'm wondering if maybe the EGR could be kicking in when it should not be (cold engine). If that were the case, then likely a thermal vacuum switch may have failed in the open position. Is there a way to test the switch?
Any other ideas? Thanks!
Old Apr 18, 2009 | 10:13 AM
WAExplorer's Avatar
WAExplorer
See if you can blow through the vacuum line at the EGR valve. If you can with the engine off/cold, then the switch is bad.
Old Apr 18, 2009 | 10:08 PM
Franklin2's Avatar
Franklin2
Rev the engine when cold, and pull the vacuum line off the egr. If it has vacuum, the switch is bad. You have to rev the engine, because the egr is on ported vacuum on the carb.
Does it seem to run rougher when it's damp outside, rainy, or a heavy dew? If it does seem worse, make sure your heat duct system going to the aircleaner is working correctly.
Old Apr 19, 2009 | 07:54 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Make sure the alternator isn't bad, it could be keeping power on the choke heater with the engine not running. Also make sure the choke closes, sometimes they stick. I know mine is an absolute PITA to start if I don't drive it regularly due to the fuel in the carburetor slowly evaporating.
Thumper19
Oct 5, 2012 04:40 PM
loveless41908
Oct 12, 2011 11:00 PM
bigland
Nov 27, 2009 05:55 AM
86rustbucket
Mar 13, 2008 06:41 PM
84-250
Mar 2, 2003 11:19 AM
