Transmission identification
Old Nov 28, 2002 | 07:55 AM
tbob's Avatar
tbob
Post Transmission identification
Old Nov 29, 2002 | 07:22 PM
jetta4's Avatar
jetta4
I have 3 questions #1 how can you tell the difference between a T18 , T19 & NP435 . #2 what is a 4 spd out of a early 70s truck(is it a NP425?) .#3 will the early 70s 4spd fit in place of a T18 in a 1982 f350 ? Can anybody help me out?
Old Nov 29, 2002 | 08:31 PM
steve83's Avatar
steve83
T-18 is unsynchronized; T-19 has synchros.
NP-435 has the "NP" gear cast into the side.
They're pretty much interchangeable.
Old Nov 29, 2002 | 08:41 PM
jetta4's Avatar
jetta4
Is the early 70S 4spd a NP435?
Old Nov 29, 2002 | 08:56 PM
steve83's Avatar
steve83
[updated:LAST EDITED ON 29-Nov-02 AT 09:59 PM (EST)]Probably a T-18, according to http://www.motivegear.com/tech_info/tranny_guide/tranny_guide.html
Old Nov 29, 2002 | 09:09 PM
kspilkinton's Avatar
kspilkinton
Could be either the T-18 or NP-435 as they were both used in early 70's trucks. The only way you're going to know for sure is to crawl underneath and look for the tag on the PTO cover, the NP symbol, or the shift tower. The NP shift tower will be aluminum. The Borg Warner will be cast steel. Bring a magnet.
The T-19, with it's synchronized first gear, wasn't around until sometime in the very late 70's or very early 80's.
If you pull the older tranny, some food for thought:
Check your input shaft length and spline count. Some of these transmissions may not readily fit up. Spline counts and shaft lengths changed.
-Kerry
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
