Rug? Transmissions
Old Nov 26, 2002 | 05:51 AM
tbob's Avatar
tbob
Rug? Transmissions
I recently pulled a 4 speed OD transmission out of a 1985 e-150 econoline with all the attendant hardware (pedal cluster, bell housing, hydraulic clutch, etc, etc.) As I like shifting, and I have a 88 e-150 with a 351/auto, with a worn out auto, I am going to put this setup in my econoline. However, I was wondering, will this transmission hold up behind the 351? I cant seem to find much info on this transmission setup in FTE. It appears that this transmission is an RUG. Thanks for your help.
Old Nov 27, 2002 | 08:27 AM
Opera House Works's Avatar
Opera House Works
Rug? Transmissions
Old Nov 27, 2002 | 10:36 PM
Njbmx's Avatar
Njbmx
Rug? Transmissions
[updated:LAST EDITED ON 27-Nov-02 AT 11:43 PM (EST)]the rug tranny is strong. the un-overdrive versions were used on mustangs and other ford and mercury cars in the 60's and 70's. only the overdrive versions were used on trucks. i dont know what gearing the one in your truck has but i've heard from a friend's '82 e-150 that it has a granny gear. i would think that the tranny would hold up to the torque of the 351, but i dont think the bellhousing would fit. also, i would rebuild the bearings in the trans before swaping the tranny just to make sure.
the 4sp. toploader is basicly the same design as the 3sp. tranny. i swapped the 3sp. from an '83 f-150 in place of a beat 3sp-od clark tranny. i converted it from the column to the floor using the hurst indy shifter kit. the convertion is a good idea, but you have to dial the linkage in perfectly or the shifter will get stuck.
pete
Old Nov 27, 2002 | 10:52 PM
Ford_Six's Avatar
Ford_Six
Rug? Transmissions
Is it a toploader? I have seen many of these blown apart. Mostly, the pocket bearing goes in them, and they sound like a diesel in any gear but third. And fourth is so high that you have to be doing 80+ just to get into it. If I was looking for an OD, I would get a 5 speed. If I wanted a four speed, I would go with an NP435 or T-18. Never an SROD. Personally, I'd just rebuild the auto with a full manual valve body.
Jared
Old Nov 28, 2002 | 07:55 AM
tbob's Avatar
tbob
Post Rug? Transmissions
Jared, yes, it is a toploader. I actually have 2 of these transmissions, as I pulled one from a parts 78 truck(with a 302) a couple of years ago. they definately are OD transmissions. As I use my econoline for more highway use, the OD is a really valuable feature. I also put together a 1967 F100 on a 1979 F1504WD frame with the np435/np205 combo, rebuilding both gear boxes and both axels, etc. Most people I speak to around here confuse the RUG trans with the NP435. As far as I know, the Rug is not equipped with a granny gear, the np435 is. also, the np435 ia about 3 times the size of the RUG. I could rebuild theC6, but I really hate autos. There seems to be very little info about the Rug, even in the archives. I really am wondering about its overall durability. I don't abuse my stuff, but I will put a lot of miles on. Thanks for your info. Tbob.
Old Nov 28, 2002 | 08:06 AM
tbob's Avatar
tbob
NBJMX, Thanks for your input. The bell housing will work, as I hace a 351 windsor, not a 351m, so I am ok. I found a website about RUG transmissions, but for some reason, it only covers up to 1973. As you said, the cars had this trans with a 4 speed hotrod kinda thing, but the trucks had the OD, which is what I want. Most of these trannys I have seen are in trucks with 300 sixes or 302's, nothing larger, although a post in the archives spoke of one behind a 400M. I also built a 1967 F100 on a 1979 4WD frame with a np435/np205 combo, and that works good, except it is a little busy at speed. It would be good to have the OD, if it would hold up. Thanks for your input. Tbob.
Old Nov 28, 2002 | 02:59 PM
gearman's Avatar
gearman
Rug? Transmissions
I have rebuilt several RUG transmissions. They are very reliable units & I wouldn't be afraid to put one behind a 351. One thing I notice that if You use O/D alot--change the lube more often. The O/D gear on the M/S will wear out alot sooner if the lube has broke down.
Old Nov 30, 2002 | 05:50 AM
inliner's Avatar
inliner
Rug? Transmissions
I have an RUG-CL tranny that I'm going to install in my '68 w/300. Can you tell me how you installed and removed the input and output bearings? I've been looking for the tools to do this and have been unable to find any. Sears sells a three prong puller that they say is for input transmission bearings, but it doesn't look long enough to remove the outputshaft.
fightlivefree
17
Nov 16, 2020 10:25 AM
hughmsmall
2015 - 2020 F150
29
Mar 15, 2017 12:18 PM
fmprdwg
2015 - 2020 F150
Mar 1, 2016 11:47 AM
señorEddie
Dec 10, 2015 08:09 PM
inliner
Dec 19, 2001 06:26 AM
