Sponsored by: Real Truck
Auto trans question
Old Apr 17, 2009 | 09:57 PM
Macamon's Avatar
Macamon
Auto trans question
Sorry for my ignorance, I've been driving a manual for the past 15 years...
When you are driving at a constant speed and whomp on the gas pettal, should the tack:
a. stay put and slowly rise with the speed
b. slide up about 500 rpms and rise with the speed?
Last edited by Macamon; Apr 17, 2009 at 10:52 PM. Reason: Observed that something was incorrect
Old Apr 18, 2009 | 08:41 AM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
It depends on what speed you are going.It should downshift to a lower gear and raise the rpms quite a bit when you stomp on it.Either way the rpms should rise rather quickly.
Old Apr 18, 2009 | 09:52 AM
soutthpaw's Avatar
soutthpaw
as posted above.. when u floor it it will downshift and unlock the torque converter giving a big jump in RPM then you will see the RPM rise slightly while the speed increases quite a bit until the Torque converter locks completely and then you will see a preportional increase between RPM and vehicle speed beyond that point...
A torque converter is a fluid coupling that allows slipage between the engine and trans. once its locked up based on engine speed and torque then its like a manual trans clutch with a solid connection between engine and trans
Old Apr 18, 2009 | 04:42 PM
Macamon's Avatar
Macamon
Which would make a 5-800rpm increase when accellerating normal, right?
I'm noticing some odd shifting too... Kinda like 3rd gear gets skipped sometimes (huge drop in R's). I understand there is a computer that can be reset to delete what it has learned... Would reseting the shift computer (disconnecting battery for 5 minutes) help that?
Old Apr 18, 2009 | 05:33 PM
WestxSRT10's Avatar
WestxSRT10
b. is more likely than a.
Old Apr 19, 2009 | 09:07 AM
aldridgec's Avatar
aldridgec
On a 7.3 w/ 4r100 (what you have), it will seem like a huge drop in the RPM's sometimes. It's the combination of TC locking and shifting into 4th that makes it seem that way.
Old Apr 19, 2009 | 12:06 PM
Macamon's Avatar
Macamon
Thanks aldridgec. That makes sense. I pulled battery terminals off for 5 minutes last night... Looked at how ugly everything was and decided to do maintainance on the terminals. Two hours later (I'm sure the trans program was reset by then :P) I put it back together. I still need to take for a testdrive.
