460 or bust?
Old Apr 17, 2009 | 08:39 PM
swiftkick5000's Avatar
swiftkick5000
460 or bust?
ive been trying to decide which engine to put into my 72 f100. it has a 400 in it now and im about to pull the gas guzzling oil leaker out of there. i can get a 460 brand new for a halfway decent price and was wondering if the transmission is the same as the 400, if it is the same length. i am trying to get away with using my tranny crossmember. also, are the steel motor mounts the same? i have at least a month before im going to need to get ready for this.
Old Apr 17, 2009 | 08:41 PM
swiftkick5000
plus, is there a difference between a 460 from a car, than a truck engine?
Old Apr 18, 2009 | 07:18 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The oilpan sump and pump pick up are in the front not the rear.
The 400M has the same bellhousing pattern as the 385 engines.
Old Apr 18, 2009 | 10:07 AM
johnyhunter's Avatar
johnyhunter
rucks and car tend to use different brackets for accessories. try tyo get a truck motor or at least the brackets. It will be help full to snap some pictures before you take them off. When I did mine I had to get a larger exhaust pipe 'flare' to fit my 460 manifolds. just a 1-2 ft piece. I also used L&M motor mounts. The motor its self bolts right in without moving the trany.
Old Apr 18, 2009 | 10:09 AM
johnyhunter
Also in 4x4 apps you need a 4x4 oil pan and pickup. Van pans work for 4x4 trucks.
crazypurple78
Aug 13, 2016 08:18 PM
Khauler
Dec 31, 2011 02:54 PM
1982fordf100
Engine Swaps
Dec 25, 2005 08:37 PM
olfordsnstone
Nov 22, 2003 09:19 PM
mark123456
May 7, 2002 01:18 AM
