stock fuel bowl with electic pump
Old Apr 17, 2009 | 06:52 PM
don77's Avatar
don77
can you use electic pump with stuck fliter bowl in the 96 and does anybody have the fuel systum diagram
Old Apr 17, 2009 | 07:04 PM
BlueMule's Avatar
BlueMule
No can do, the stock bowl won't handle the pressure.
Old Apr 17, 2009 | 07:09 PM
250turbo's Avatar
250turbo
our lift pump is two stage,low pressure to filter . than return to pump & gets kick up to fuel rail & frp. frp to filter& return
Old Apr 17, 2009 | 07:17 PM
plowhand's Avatar
plowhand
Playing in the Dirt
First, discription of our fuel system (short version) the pump pulls fuel from the tank through the low pressure side on the pump and pumps it (at low pressure) through the fuel filter housing and then back to the fuel pump where it enters the high pressure side of the pump where it is pumped (under high pressure) through the banjo bolt and through the fuel passages in the heads to the injectors and then out of the head to the FPR (Fuel Pressure Regulator) which bleeds off any pressure over the preset (thus maintaining pressure) and allows the excess fuel to return to the tank (with a small amount returning through the small screen back into the fuel filter housing).
So, BlueMule is right and wrong, yes you can use the stock filter housing with two pumps ( low pressure lift pump before the filter housing and then a high pressure pump after the housing, and alot of plumbing and line relocation and you will still have a valley full of stuff, a stock regulator that is hard to adjust, etc. --which equals small benefit for alot of work)
One of the big benefits of electric fuel is cleaning up the valley (making engine repair easier and relocating everything under the truck so if a leak develops it's easier to service and less messy).
Hope this explains it for you.
Old Apr 17, 2009 | 07:44 PM
don77's Avatar
don77
yes it did alot thinks for telling i been trying to figer this out for days
Old Apr 17, 2009 | 07:56 PM
BlueMule's Avatar
BlueMule
Good Job!
I knew all that but I also know how long it would take me to type all that with two fingers.
Old Apr 17, 2009 | 09:48 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Originally Posted by BlueMule
Good Job!
You use two fingers, I only use one .......guess I'll have to take classes. LMAO
Tomget
Feb 15, 2014 10:24 AM
1jrhinehimer
1978 - 1996 Big Bronco
Mar 11, 2011 05:38 AM
e william
35
Feb 3, 2009 06:03 PM
85 FORD MAN
16
May 29, 2004 11:19 PM
