2006 F150 P0106 error
Old Jan 29, 2013 | 09:35 PM
Ron Purpura's Avatar
Ron Purpura
Hello all
New user to the forum.Hoping I can get some help from the experts here.
I have a 2006 F150 with 60K miles.The power plant is the 4.6 L I have been getting the p0106 error for quite some time. Changed the EGR valve out and error went away for a few months...Error came back after a few months and cleaned the throttle body...Error came back again recently.. cleaned the MASS AIR sensor with the CFC Cleaner and the error still persist. After each try,I did dis-connect the battery...
Does it sound like an electrical connection issue? if so,what or where should I be looking?
Any help or insight is greatly appreciated..This truck has been very good to me,and plan on keeping it around for quite some time
Thanks in advance
Ron
Old Mar 11, 2013 | 05:47 PM
dotskip's Avatar
dotskip
P0106 - MAP/Barometric Pressure Circuit Range/Performance Problem Article by Dale Toalston ASE Certified Technician OBD-II Trouble Code Technical Description Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem What does that mean? The Powertrain Control Module (PCM) uses the Manifold Absolute Pressure Sensor (MAP) to monitor engine load. (NOTE: Some vehicles have a Barometric Pressure (BARO) sensor that is integral to the Mass Air Flow (MAF) sensor and do not have a MAP sensor. Other vehicles have a MAF/BARO and a redundant MAP sensor where the MAP sensor functions as a backup input in case of MAF failure.) The PCM supplies a 5 Volt reference signal to the MAP sensor. Usually the PCM also supplies a ground circuit to the MAP sensor as well. As the manifold pressure changes with load, the MAP sensor input informs the PCM. At idle the voltage should be 1 to 1.5 Volts and approximately 4.5 Volts at Wide Open Throttle (WOT). The PCM looks for any change in manifold pressure to be preceded by a change in engine load in the form of changes in throttle angle, engine speed, or Exhaust Gas Recirculation (EGR) flow. If the PCM doesn't see any of these factors change while detecting a rapid change in MAP value, it will set a P0106. Potential Symptoms The following could be symptomatic of a P0106: Engine runs rough Black smoke at tailpipe Engine will not idle Poor fuel economy Engine misses at speed Causes A P0106 could be caused by: Bad MAP sensor Water/dirt intrusion affecting MAP sensor connector Intermittent open in the reference, ground, or signal wire for the MAP sensor Intermittent short in the reference, ground, or signal wire for the MAP sensor Ground problem due to corrosion causing intermittent signal problem A break in the flexible air intake duct between the MAF and the intake manifold Bad PCM (do not assume the PCM is bad until you've exhausted all other possibilities) Possible Solutions Using a scan tool, watch the MAP sensor value with the key on, engine off. Compare the BARO reading with the MAP reading. They should be roughly equal. The voltage for the MAP sensor should read approx. 4.5 volts. Now start the engine and look for a significant drop in the MAP sensor voltage indicating the MAP sensor is working. If the MAP reading doesn't change perform the following: With the Key on, engine off, disconnect the vacuum hose from the MAP sensor. Using a vacuum pump, pull 20 in. of vacuum on the MAP sensor. Does the voltage drop? It should. If it doesn't inspect the MAP sensor vacuum port and vacuum hose to manifold for a restriction of some kind. Repair or replace as necessary. If there are no restrictions, and the value doesn't change with vacuum, then perform the following: with the Key on and engine off and the MAP sensor unplugged, check for 5 Volts at the reference wire to the MAP sensor connector with a Digital Voltmeter. If there is none, check for reference voltage at the PCM connector. If the reference voltage is present at the PCM connector but not the MAP connector, check for open or short in the reference wire between MAP and PCM and retest. If reference voltage is present, then check for existing ground at the MAP sensor connector. If it isn't present then repair open/short in the ground circuit. If ground is present, then replace MAP sensor. Other MAP sensor trouble codes include P0105, P0107, P0108 and P0109.
Read more at: P0106 DTC Code - Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
Copyright © OBD-Codes.com
Old Mar 12, 2013 | 07:50 AM
Ron Purpura
Thanks so much for the info. Looks like I will be busy this weekend
Thanks again
Ron
brichert
May 26, 2017 06:46 AM
pjnadon
Jan 22, 2011 10:01 PM
76250_4x4
Aug 12, 2010 10:09 PM
dlburch
Jan 12, 2008 10:47 PM
dant
Apr 1, 2004 07:28 AM
