Traction bar Project.
Old May 23, 2009 | 10:51 PM
  #31
shark1979's Avatar
shark1979
just a question but why did you weld the tubes to the center section? the traction bars look real good by the way. what kinda tube did you use for the bars? thinking of building a set myself.
Old May 23, 2009 | 10:52 PM
  #32
Adam0331's Avatar
Adam0331
Looks good Kris. I'm working on getting stuff together for a set.
Old May 23, 2009 | 11:23 PM
  #33
jdecker88's Avatar
jdecker88
Great job Kris that is pretty impressive, no axle wrap now .
Old May 24, 2009 | 01:44 AM
  #34
That_Guy's Avatar
That_Guy
Thats pretty damn good stuff there Kris, those welds are pretty good.
Old May 24, 2009 | 12:07 PM
  #35
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Thanks for the compliments guys.
Josh, if you were not aware, axle wrap comes from the pinion spinning 90* from the ring gear, trying to wrap itself up around the ring gear, which has a leverage ratio of ~3-4:1 on the ring gear. When you add more torque, that pinion gets more leverage, and ends up wrapping the entire axle housing up. Well we put bars on the axle to stop movement, however stop movement of the TUBES. The centersection still has the urge to spin up, and on several cases, i've seen pictures of that center section pointed straight up. Welding the tubes to the housing as much as you can gives it more strength, and peace of mind. Now the pinion and ring/carrier are out, im debating on tacking the tubes on the inside of the housing too, just because it's there...
Old May 24, 2009 | 01:10 PM
  #36
beanhead6D5's Avatar
beanhead6D5
Very good job Kris,looks great! Tryed to rep you and I am in time out,I'll get you later.
Old May 24, 2009 | 03:20 PM
  #37
farmb0y's Avatar
farmb0y
Nice job, the powdercoating sure makes it look factory!
Hopefully you don't have to grease your front joint too often, it'll be hard to get a grease gun too it.
It's definitely a great feeling building something yourself and being able to see the finished product. I help a neighbor build farm equipment and it's fun finish it and be able to go out and use it in the field.
X_Hemi_Guy
Jul 14, 2012 08:56 PM
DarrinGT
Engine Swaps
189
May 14, 2012 10:21 PM
onyxxtreme
13
Mar 7, 2012 09:47 PM
foxracing0934
183
Mar 18, 2010 08:22 PM
suzuki1750
Offroad & 4x4
110
Jul 24, 2009 12:00 PM
