General Diesel Discussion
1984 F250 Starting Problems
Old Apr 15, 2009 | 06:50 PM
circllb's Avatar
circllb
Have a 1984 F250 Diesel will not start. Does this truck have a push button for the glow plugs. When plugged in to electric should the heater for the glow plugs get warm. Help
Thanks
Old Apr 15, 2009 | 08:46 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I'll assume it turns over.
How fast, They need to spin pretty fast, Good batteries are a must!
Not unless some one wired one in, they come from the factory with a GP (Glow Plug) controller. Not a push button.
Do you get a WTS (Wait to Start) light on the dash?
How long does it stay on, 10 seconds or so is about right, much less and you likely have bad GP's.
To test the GP, use a volt/ohm meter set to continuity (ohms), unplug the GP's, put one lead on the GP terminal, the other to ground ... It should show like a dead short.
Does the GP solenoid click on and off?
Does the GP solenoid pass power through it when energized?
Plugging in is for the block heater.
-Enjoy
fh : )_~
1984_IH6.9_Project
44
Jul 12, 2016 09:55 PM
1984_IH6.9_Project
Jun 13, 2016 09:19 PM
towjoe42
Jul 12, 2015 04:52 PM
SteveNCf250
Jan 21, 2013 05:58 AM
JakeSherlock
27
Apr 17, 2009 11:16 PM
