HPOP failed
Old Apr 15, 2009 | 03:21 AM
big_coyote_hunter's Avatar
big_coyote_hunter
Unhappy HPOP failed
Hey guys, I'm sure you've heard this before but I couldn't find anything about the High Pressure Oil Pump.
I have a 2003 F350 Duallie with Volant intake, Edge with attitude, and straight piped exhaust. My HPOP went out and its a pretty expensive part. I'm wondering if anyone knows why these go bad and if it was caused by my chip? I'm relatively new to the diesel world but I wouldn't go back for anything.
Is there somewhere I can get a reman? Or a kit to do it myself? I'm quite capable of doing the work but I'm in college and don't have much money for the parts.
Any help would be appreciated. Thanks
Nick
Old Apr 15, 2009 | 06:25 AM
jamie7375's Avatar
jamie7375
If you have an international dealer near you you can get the pump from them for considerably less than you can through the Fod dealer. the part number for the HPOP on my 04 is 5010106R92 and I believe it should be the same for yours...just a thought
Old Apr 15, 2009 | 07:19 AM
bismic's Avatar
bismic
Welcome to FTE big_coyote_hunter.
The International part numbers I have for the 2003 and 2004 HPOP are:
International part # 5010106R93
Ford part # 3C3Z-9A543-AARM
or
International part # 5010119R92
Ford part # 4C3Z-9A543-AARM
jamie7375's suggestion to go to an International Dealership is a good one. However, his number does not show up on my list, but I believe mine are correct. I am not completely sure why there are two numbers but I believe the second one to be more recent. Perhaps one of them is a kit instead of the individual pump. Unless someone posts here, you should ask about this question where ever you end up buying the pump at.
You can also contact FTEPartsguy (a site sponsor) - he is a big help and has good prices. Being new, I believe you can only send him a visitors message.
or
His website is:
http://www.trademotion.com/partlocat...?siteid=215005
Old Apr 15, 2009 | 07:35 AM
jamie7375's Avatar
jamie7375
Yours are right...Mine are off (my paper got wet)....thanks for the correction
Old Apr 15, 2009 | 07:36 AM
joe blow's Avatar
joe blow
What makes these fail?
Is it in the oil pan?
Old Apr 15, 2009 | 08:17 AM
ljutic ss's Avatar
ljutic ss
It's under the turbo, Mechanical pump driven by a gear probably failed due to wear like anything else.
Old Apr 15, 2009 | 09:27 AM
joe blow's Avatar
joe blow
I was just in there.....is it the unit where the turbo drain line plugs into?
Old Apr 15, 2009 | 10:22 AM
jackles's Avatar
jackles
http://www.powerstrokehelp.com/6liter/6vs7/4of6.asp
Here is an informative video site that I stumbled across that may help answer your question (as well as others). In particular on your HPOP question, Part 4 may help explain why it fails and the location.
Hope this helps. Good Luck!
Old Apr 17, 2009 | 12:26 AM
big_coyote_hunter
Thanks everyone for your help. There is an international dealer just up the road. I'll swing in in the morning and see what they can do.
Jackles... That video was very helpful actually. He said bad oil can cause it to fail. It just so happens that my injector seals were fried and raw fuel was leaking past and into the oil. So I'm asuming that by not changing the oil immediately I brought this on myself.
Moral of the story: Keep up with your maintanance. OR ELSE...
Old Apr 17, 2009 | 07:50 AM
riggz's Avatar
riggz
Too bad it didn't happen a month or so from now. There's a new aftermarket HPOP in the works.
Old Apr 17, 2009 | 08:43 AM
PowerStrokeHD's Avatar
PowerStrokeHD
or
Your numbers (Ford and International) are right and are for the pump. 3C3Z is for '03 and early '04 while 4C3Z is for late '04.
Old Apr 17, 2009 | 05:25 PM
big_coyote_hunter
The International dealership said that the HPOP was a restricted part and they couldn't sell one to me. That I'd have to get it through Ford. They weren't for sure tho.
Riggz... Do you have info on that a/m HPOP? I could wait for it if its gonna be worth it.
Old Apr 17, 2009 | 05:32 PM
liv's Avatar
liv
Have someone else go in and tell them you are putting it on a a vt365 in a school bus
Old Apr 17, 2009 | 06:32 PM
big_coyote_hunter
I was wondering if it was used in another vehicle... Are you sure the parts are compatable? What year bus am i telling them? I'm assuming that vt365 is the engine they will need to know?
Old Apr 17, 2009 | 06:33 PM
riggz's Avatar
riggz
Bob Riley will have info available in the next few weeks for beta testing. www.dieselsite.com
