Broken axle removal
Old Dec 10, 2002 | 10:49 AM
Brian460's Avatar
Brian460
Broken axle removal
Hey I have broke a 10.25" axleshaft, what do I get?
Old Dec 10, 2002 | 01:20 PM
jalampi's Avatar
jalampi
Broken axle removal
The easy halfass way to remove that piece of broken shaft is to put a rag in the housing and drive around until it falls out of the spider gear then slide it to the end of the axle tube with a long piece of wire.Then grab it with a set of long needle nose pliers.
Those longer spline axle shafts can be cut with a die grinder so long the splines go high enough up the shaft.
1997 F350 PowerStroke,5 Speed, 4X4,36 Inch Buck Shot Mudders, Strait Piped, Chiped, Propane Injected, LUK Clutch, Reverse Shackle Kit
Old Dec 10, 2002 | 02:09 PM
85351ho's Avatar
85351ho
Broken axle removal
brian460....you dont get anything....just stay off the skinny pedal
Old Dec 11, 2002 | 12:53 AM
Brian460's Avatar
Brian460
Broken axle removal
Geee Thanks
2006lariat
Sep 16, 2012 11:01 AM
tdm3480
Nov 22, 2008 07:47 PM
CougarXR02
1983 - 2012 Ranger & B-Series
16
Jan 3, 2008 08:19 PM
Soilman
Offroad & 4x4
15
Jun 26, 2007 12:06 PM
td351w
Dec 1, 2002 11:12 PM
