Rough starts
Old Apr 15, 2009 | 04:29 PM
liv's Avatar
liv
Originally Posted by liv
Take her in. Remember there's no deductible on emissions equipment if there it's the eye valve
I need to quit posting from my phone stupid thing messes up my spelling more than it helps
Take her in. Remember there's no deductible on emissions equipment if it's the egr valve
Old Apr 15, 2009 | 10:29 PM
riggz's Avatar
riggz
lol. i hear ya. they started working on it this afternoon. I called up there just before closing time and they said they haven't nailed it down yet but they were focusing on the FICM. I'm pretty sure this is covered under the warranty. If not my 3rd party extended warranty will. I'm still on the fence if they should charge the $100 deductible though. The wording in the warranty is contradicting as it says it's only free if your state does emmisions checks which mine does not.
Old Apr 16, 2009 | 06:38 AM
bismic's Avatar
bismic
From what I have seen, FICM failures usually come w/ a number of DTC's. Also, if it only happens when cold, it is surprising that it is a FICM issue. Keep us informed. Several years ago, my dealership agreed that even though we do not test emissions here, that the emissions warranty (and no deductible) still applied. Maybe w/ the economy issues they have changed their tune. Let us know how this turns out too.
Old Apr 16, 2009 | 06:07 PM
riggz's Avatar
riggz
They ended up replacing the FICM. The tech said they usually fail because of a voltage regulator or transformer (something along those lines) goes bad or pops. When it goes bad it doesn't send enough fuel to the injectors so thats why it was dying. Starts up perfect now! I didn't plug my SCT in to pull any codes, so I don't know if there were any. I figured my DashHawk would alert me if there were any since I have it set to alert me if there is 1 or more codes. There were however a long list of codes on the repair bill.
I paid the $100 deductible. I couldn't find anything that was solid in the warranty book about the emissions warranty being 100k miles or that the FICM was covered. I don't really have an issue since the repair bill would have been $1400!
Old Apr 16, 2009 | 06:38 PM
liv's Avatar
liv
Yea its not covered under the emissions warranty. Only the EGR system and such is.
Not surprising it was the FICM, has been happening a lot lately with a weak electrical system and the new flash. No one mentioned it right off the bat because it usually doesn't cause the symptoms you listed. It usually just won't start or dies.
Did they load test your batteries and alternator? If not it might be worth getting them tested so it doesn't happen again.
Good to hear your back on the road though. Thanks for keeping us updated.
Old Apr 16, 2009 | 06:44 PM
riggz's Avatar
riggz
My batts and alternator weren't load tested but I feel they are running ok. I have 14v when running down the road and the batts are fairly new. The alternator was just replaced under warranty. (It's a large case 200amp heavy duty from alternatorparts.com)
Old Apr 16, 2009 | 08:01 PM
riggz's Avatar
riggz
Here's a video of what it sounded and looked like. You can see the black smoke coming out in the lower mirror. I didn't catch any of the times it started and crapped out on me cuz I started to get P.O. at that point heh.
YouTube - Bad Ford 6.0L FICM
Old Apr 16, 2009 | 08:03 PM
FORDSDOWNER's Avatar
FORDSDOWNER
riggs,
if I am not mistaken, sometimes 1 or more injectors are likley to go south after or even during an FICM failure. But I guess that is also related to just how severe the problem was.
Old Apr 16, 2009 | 08:05 PM
liv's Avatar
liv
That sounds AWFUL it almost made me cry
Does your starter normally sound like that or is that the sound of it partially firing making that noise?
Nice mirrors also... I'll give you 50 bucks for them and you can have my torn up old ones. Great deal right?
Old Apr 16, 2009 | 08:20 PM
riggz's Avatar
riggz
It sounds like that because its not fully firing. It sounds normal now. As for the mirrors, you can have them for $50 + this bike :
Old Apr 16, 2009 | 08:22 PM
riggz's Avatar
riggz
Originally Posted by FORDSDOWNER
riggs,
If the sticks crap out on me I'll have em replaced under warranty as well. Then I'll take em out and sell em for a better price than I would have gotten for my old ones and get some bigger ones.
Old Apr 16, 2009 | 09:01 PM
liv's Avatar
liv
I was a signature away from buying an 07 red r6 last week. Talked myself out of it. You can have my gixxer though =D
Old Apr 16, 2009 | 09:03 PM
  #28
riggz's Avatar
riggz
Just FYI here's the codes listed on the repair bill:
P0261
P0264
P0267
P0270
P0273
P0276
P0279
P0282
P0611
P2290
P2291
Listed TSB 08-18-06, 08-26-03
The part # for the FICM was 4C3Z 12B599 AARM
Old Apr 16, 2009 | 09:06 PM
  #29
riggz's Avatar
riggz
Doh! That red is sexy! Someone stole my silver/black 03 R6 a couple weeks ago. Waiting on insurance to cut me a check.
Old Apr 16, 2009 | 09:11 PM
  #30
miner999r's Avatar
miner999r
Glow plug controller used to be a PITA in the 7.3 I had. Do the 6.0's have a similar issue.
Had a GM 6.2 in a sub with a bad glow plug. A pig to start and smoke like a forest on fire till the cylinder warmed up.
