trouble starting
Old Apr 14, 2009 | 10:15 AM
stephenfaustin's Avatar
stephenfaustin
trouble starting
****** http-equiv="Content-Type" content="text/html; charset=utf-8">****** name="ProgId" content="Word.Document">****** name="Generator" content="Microsoft Word 11">****** name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5Ce135913%5CLOCALS%7E1%5CTemp%5Cms ohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> 95 F-150 5.0
this morning when it took me three time to get the truck to start. The first time all I heard was the starter, the second time the engine stumbled for five seconds then died. The third time I held the gas peddle down a little and it started right up. The truck ran fine all the way to work, through traffic and everything. Anyone know what might be about to go?
Old Apr 14, 2009 | 11:19 AM
subford's Avatar
subford
Fuel pressure regulator maybe, pull the vacuum line off its nipple with the cold engine running and see if any fuel comes out, if it does it is bad.
OR
Maybe an injector is starting to leak.
Old Apr 14, 2009 | 02:30 PM
hotstang's Avatar
hotstang
check codes
My problems ended up being a bad temp sensor (code 21). If it has fuel and spark I would check this next.
defcon4
Jul 4, 2010 08:59 PM
snakedoc
Jun 30, 2009 07:15 PM
bill015
Paint & Bodywork
Jun 16, 2009 04:08 PM
edzakory
Mar 19, 2009 08:24 PM
Midnightride42
1997 - 2003 F150
Nov 18, 2008 05:22 AM
