Vaccuum modulator replacement? 1980 C6
Old Apr 14, 2009 | 09:46 AM
Hometown Pride's Avatar
Hometown Pride
The vaccuum modulator leaks transmission fluid when I pull the hose from it. I'm going to get a new one right now. Could someone explain how to install the new one.
Is fluid going to come pouring out?
Do I need to purchase anything else to complete the install?
Thanks for the help.
Old Apr 14, 2009 | 09:56 AM
dustybumpers's Avatar
dustybumpers
undo the bolt and remove the clip. yes some fluid is going to come out, not a lot. don't loose the rod . clean yours to get the #'s off, there's like 4 different ones.when you put it back, make sure to replace the rubber line on both ends, the oil satureates the rubber, and it will suck it flat causeing erratic shifts. there is a adjustment for the shifts inside where the vaccume line hooks on,use a small screwdriver, in for firmer shifts, out for softer
Old Apr 14, 2009 | 01:37 PM
Hometown Pride
Thanks for the info, I just got one. I'm hoping its got the same numbers. Should I just put the pin in the new one and reinstall, and see how it shifts before I make any adjustments
Old Apr 14, 2009 | 03:16 PM
dustybumpers
yes, the adjustment is for personal preferance of where it shifts. I usually put them in then go for a spin. catch a hill or two, stomp it a couple of times, etc. if your pleased, ok, if not, just pull off the hose, and turn 1/4 turn at a time. in for firmer[quicker] out for softer [slower]
Old Apr 14, 2009 | 05:43 PM
Hometown Pride
Are you talking about the nubers on the pin or the modulator? My mod doesn't show any numbers.
Old Apr 14, 2009 | 06:53 PM
dustybumpers
should be numbers ink stamped into the side of the mod body. if none, it is probably already a replacement. if that's the case just get whatever is available
Old Apr 14, 2009 | 06:54 PM
Franklin2's Avatar
Franklin2
When I bought one it had color bands on it instead of numbers. You should have been through all of this when you went to the parts store if there was a problem. If they just gave you one, stick in on and see what happens.
Old Apr 15, 2009 | 05:06 PM
Hometown Pride
stuck it on, lots of fluid came out. It has lengthened the time between shifts which is nice. Still get a clunk when I come to a stop sometimes. I am going to bring it to the mechanics for a band adjustment, I dont want to break anything.
Old Apr 15, 2009 | 05:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford used bands of color to ID modulator valves, not numbers.
There can be one color band, two or possibly three.
The early valves (thru 1970) were not marked because there were only three: One for C-O-M, one for F-O-M, the 3rd was used for the C6 & C4.
No number on the pin....cuz....its diameter is waay smaller than a toothpick!
Old Apr 15, 2009 | 05:21 PM
Hometown Pride
Man you use some big tooth picks. Anyways I picked one up It had numbers on it. Didn't see no colours. Courtesy, Canadian Tire.
Old Apr 15, 2009 | 05:29 PM
NumberDummy
The pin (D8AZ7A380A) has no number of any kind on it...because it's 1/8" diameter.
After 1970, the factory modulator valves have color bands.
coppertales
21
Apr 6, 2015 02:57 PM
forddriverforlife
Feb 8, 2015 10:26 AM
pat420swed
Jan 1, 2015 12:39 PM
427 fordman
13
Nov 30, 2014 01:29 PM
stroker393
Nov 11, 2008 08:57 AM
