How to fix dent in tailgate?
Old Apr 14, 2009 | 09:38 AM
flysniper's Avatar
flysniper
How should i fix this.
<table style="width:auto;">
<tr>
<td><a href="http://picasaweb.google.com/lh/photo/i3sMYbUdhG3KWhvxiYwYLQ?authkey=Gv1sRgCIiv6PTz4-u14AE&feat=embedwebsite"><img src="http://lh6.ggpht.com/_3b0pBjmjtd0/SeSWirjD_dI/AAAAAAAAAoQ/0ytyE4eXp0g/s144/DSC_0095.JPG" /></a></td>
<td><a href="http://picasaweb.google.com/lh/photo/NllLJSQga9DKz8BLbeQAbg?authkey=Gv1sRgCIiv6PTz4-u14AE&feat=embedwebsite"><img src="http://lh6.ggpht.com/_3b0pBjmjtd0/SeSWisin9lI/AAAAAAAAAoI/pMIwKJTjhCQ/s144/DSC_0092.JPG" /></a></td>
<td><a href="http://picasaweb.google.com/lh/photo/Onf4gzC6XEHEf1hc3ItM5g?authkey=Gv1sRgCIiv6PTz4-u14AE&feat=embedwebsite"><img src="http://lh3.ggpht.com/_3b0pBjmjtd0/SeSWilqceBI/AAAAAAAAAoA/JH_0cF5TwZU/s144/DSC_0091.JPG" /></a></td>
</tr>
<tr>
<td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.earnheart/ProjectF100?authkey=Gv1sRgCIiv6PTz4-u14AE&feat=embedwebsite">Project F100</a></td>
</tr>
</table>
Old Apr 14, 2009 | 02:36 PM
Chaosracing's Avatar
Chaosracing
Use either a stud gun and put studs on or drill holes. Then use a slide hammer to pull it out. Pull out as best as you can, then grind paint down to bare metal and use body filler to finish off. You want to try and work the metal to use as little filler as possible.
Old Apr 14, 2009 | 02:40 PM
flysniper's Avatar
flysniper
I was afraid it was too deep or too much of a crease to pull out.
Old Apr 14, 2009 | 03:03 PM
Chaosracing
You may have to shrink the metal a little as well. If you have access to a stud gun for pulling the dents out, you can use it to shrink the metal as well. If not, then you have to use some kind of torch to heat the metal up. Then quickly cool with a rag soaked in water (for both stud gun or torch).
Old Apr 14, 2009 | 05:06 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Depends on your skills and equipment. Myself, I'd rather cut it out and weld a piece in.
Old Apr 15, 2009 | 07:35 AM
Action4478's Avatar
Action4478
Drill a small hole opposite the dent ,,use a drift & a hammer ,,weld the hole shut after ,,,
tjbeggs
36
Jul 2, 2021 10:25 AM
CPUNeck
43
Dec 20, 2020 10:13 AM
tjbeggs
125
Dec 16, 2016 11:24 AM
BradyCouchman
Escape & Escape Hybrid
Jul 23, 2012 07:29 AM
jwhopson
Jun 3, 2012 12:23 AM
