4:30 vs 3:73
4:30 vs 3:73
I have to admit I'm not happy with performance of my truck with the big 305/65/17 tires, 5.4 and 3:73 gears. I am considering 4:30 gear conversion because the truck is working hard to pull my 6000 lb boat when I hit an uphill grade. The cost is the only thing holding me back, I have to change both front and rear. Gears and labor would run about $800-$1000 I figure.
Anyone bite the bullet and do the conversion? Was it worth it?
If I was running 35" tires with a 5.4, I would go with 4.56s. The cost will be the same. The performance difference will be night and day. You will more that likely get better fuel mileage too. It's the single best thing you can do for your 5.4 with the large tires.
Nothing else will come close. Not headers, a tuner or exhaust, which are all good to do after the gear change.
No gas Super Duty should come with 3.73s in my opinion.
Depends on what you do with the vehicle. You should have lower gearing if you are hauling or towing heavy, but for just moving light loads, 3.73 is fine based on stock tires.
Anyone who intends to increase their wheel/tire size should factor that in BEFORE they purchase and order accordingly (or budget for the extra expense of changing parts). Big tires and tall gearing will make your vehicle feel weak.
Well, looks like a long road to saving up for the gears and swap. Man the wife is not going to like this.....
. "Yo Baby, I need to spend a G on gears for the truck"
, "now I know the kids need to eat, but the truck needs the gears"
Yeah this pretty much sums it up. The gears next year.
