axle #'s ?
Old Apr 14, 2009 | 05:33 AM
Rob Cuenin's Avatar
Rob Cuenin
axle #'s ?
can someone tell me what these axles are front 3.50 D9TA ACB
610067-2
rear 4.10 D3TA-MA
603382-11
thanks for your replys
Old Apr 14, 2009 | 09:50 AM
bmuhlbach's Avatar
bmuhlbach
could be d9 =79 3.50 gear ratio
d3=73 4.10 gear ratio
Old Apr 14, 2009 | 10:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Rob Cuenin
front: 3.50 D9TA ACB // 610067-2
rear: 4.10 D3TA-MA // 603382-11
Front Driving Axle
Ford ID number: D9TA-ACB // Dana ID number: 610067-2
Dana 44-9F / 3.50-1 / non Limited Slip / Free Running Hubs / 3800 lb. Front Axle Capacity.
Rear Axle
Ford ID number: D3TA-MA // Dana ID number: 603382-11
Dana 60 / 4.10-1 / LIMITED SLIP.
FYI:
Just because the prefixes are D9 (1979) and D3 (1973), that doesn't mean these were the only years they were used.
EVERY year, Ford used new ID prefixes, but the facts are...the same basic axles were used 1973/79, and for the rear, thru 1985.
Bottom line: ID prefixes and especially...part number prefixes cannot be used to ID what years the parts fit.
Ford updates 10's of 1000's of part numbers EVERY year.
If...for example, you needed a 1932 Ford lug nut, the part number today is E8AZ-1012-A.
The original part number was B-1012.
Ford replaced that with: B-1012-A; COAZ-1012-A; C9AZ-1012-A; E6DZ-1012-A; and finally E8AZ-1012-A!
Old Apr 14, 2009 | 07:00 PM
Rob Cuenin's Avatar
Rob Cuenin
Thank you for replying I know that you knew that thanks (aka green machine)
someone replaced the front end just wondering what is was
rjbuningsr
1966 - 1977 Early Broncos
Dec 26, 2012 09:01 PM
hasteranger
Apr 22, 2010 02:11 PM
hokie93
Dec 28, 2009 08:51 PM
big_witt7
Mar 16, 2009 09:09 PM
cgfirefighter
Feb 25, 2009 11:43 PM
