Stock 360 power?
Old Apr 13, 2009 | 11:39 PM
Caleb1's Avatar
Caleb1
Stock 360 power?
What are torque and horsepower numbers for a stock 360 in 4x4 truck? thanks a bunch!
Old Apr 14, 2009 | 12:08 AM
85e150's Avatar
85e150
From the many-times unreliable Wiki:
215 HP at 4200, 375 tq at 3600 for 1968. These would be the old gross HP numbers, so slice as much as 20% off for the SAE Net HP calculation adopted in '71 or'72 or so, and I saw a quote of 196 HP for those, not the full 20% loss.
Old Apr 14, 2009 | 09:35 AM
Freaksh0w's Avatar
Freaksh0w
20% off 375 makes it 300. I was thinking, even with 20% off, that's still a lot of torque... until I did the math, lol. My little 302 is rated 275 ft-lbs @ 2400 RPM. I've rode in a 390 powered Ford, and it seemed to run really good. I know the 360/390 are brothers, and I expected better numbers than that. I wonder what they'd put on a dyno, since it's hard to know the real horsepower/torque numbers with the different standards and different times.
Old Apr 14, 2009 | 12:22 PM
85e150's Avatar
85e150
While the 360 and 390 are identical in almost all ways, the 360 suffers from lower compression and a below deck piston height, both proven power killers.
IIRC, the net torque number was something like 336, but I'd have to search for hours to confirm.....
The 360 does not seem to have suffered the full "20%" loss, due in part to the fact that it was already low compression and probably had a smog pump and some other early smog stuff from day one, having been a '68 intro model. The numbers drop was mostly due to the gross-to-net change, but additional smog efforts contributed as well.
Old Apr 14, 2009 | 12:25 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
What year?
Old Apr 14, 2009 | 12:26 PM
maxtor's Avatar
maxtor
The biggest problem the 360 has in making power is it's very low compression.
Because it is so easy and cheap to make more hp by installing a 3.78 stroke crank, 390 rods and higher compression pistons, and make it into a 390, that is what most people do. If you were a die hard 360 fan, all you would need to do is buy aftermarket high compression pistons, aftermarket stronger rods, better flow heads, intake, cam etc. and you would have a potent 360. It would put the hp close to the 390 but for much more money.
Old Apr 15, 2009 | 08:33 AM
Freaksh0w's Avatar
Freaksh0w
Interesting about the compression being so much lower on the 360 than the 390, I wouldn't have guessed that, but I don't have a ton of experience with these engines, either. I do know that I enjoyed my ride in the stock 390 Ford truck I rode in. Sure, it was a good running truck, but that thing seemed to have some good pep for its age. Really good pep.
I had a friend back in high school that had an old Ford with the 360 in it. He seemed to like it. Never heard him say anything bad about it, reliability or power-wise.
Old Apr 15, 2009 | 01:40 PM
krewat's Avatar
krewat
The other problem with the 360 was the 1972 and later years had different cam timing making power even lower.
Old Apr 15, 2009 | 01:43 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by 85e150six4mtod
...the 360 suffers from lower compression and a below deck piston height,
Hmmm... what about just getting even longer than 360's longer rods? :)
Fix both problems at once with that scheme. :)
(if there are any that'll fit, no matter what brand)
I haven't give up on the idea of a 390 or 410 I'm still looking for a 390 or
390 crank and rods, just not having any luck. :/
I've sure enough disappointed a bunch of guys around the area tho with
my 1/4" dowel. They weren't lyin' about their 360's being 390's, that's
what they were told and I'm beginning to think it started way back with
the dealership's sales staff. :/
Alvin in AZ
Old Apr 15, 2009 | 01:50 PM
Alvin in AZ
Sure enough. :)
After getting my 252/252 Comp "Economy" cam (set straight up)
I can feel the power band back off a little at the upper end and can't
seem to find the low end limit to the power band. Before, the sucker
couldn't pull from 31 miles an hour in forth gear and could feel no
dropping off at the upper end. Now I'm afraid to try too hard to find
the low end in 4th gear but 12 miles and hour is no sweat. :)
Alvin in AZ
Old Apr 15, 2009 | 02:03 PM
obey_your_master's Avatar
obey_your_master
If you're really lucky, a truck with a 360 out of california will have negative power output values!
Old Apr 15, 2009 | 02:31 PM
Alvin in AZ
Not just Kalifonia. ;)
My brand new '75 F150 360FE T18 came with only an EGR, PCV, lean
low speed circuit, lean idle mixture (factory set with mixture screw caps)
and the retarded cam timing ...as smog stuff.
...and couldn't pull itself from a level spot without putting it in 1st gear. :/
Believe it?
The clutch being crappy didn't help anything either. :/
(suspecting the bell housing is not straight!)
Defeating the EGR helped a bunch (did that the first few months but
couldn't be seen from the outside) but the only thing to really "fix" it
was the 252/252 Comp "Economy" cam with its "tractor like" tall
but short duration lift and its built in more advanced timing.
Alvin in AZ
ps- No pump or charcoal canister came on it.
CJK09
Mar 15, 2016 09:31 PM
CJK09
Jul 5, 2015 01:00 PM
kel1306
Nov 1, 2007 04:20 PM
