Pitman Arm removal myth Myth
Thanks Cartmanea. I borrowed a pitman arm removal tool set from Advance Auto.
I think it should more accurately be called a pitman arm PUSHER since you're pushing the end of the tie rod end out of the Steering Arm and steering knuckle.
Call me crazy.
Call me crazy.
Best bet has already been posted. Crank the puller tight, don't expect the puller to get it off itself without turning the puller to junk. Once the puller has the arm preloaded, get out of the way and give it a whack with a small sledge. Be ready to get away because the puller and pitman will fly........but it will come off.
Here's what I used, it worked great!,it works for the 99-04 also:Detail Page for 41970 Heavy Duty Pitman Arm Puller Ford - Lisle Corporation
I use a quality two arm puller. I do like the looks of the snap-on unit though. Loosen the nut and keep it on the shaft a full set of threads. Attach the puller and run it tight with the impact. Hit the arm with a mini sledge and repeat tightening and hitting until loose. Leaving the nut on the end of the shaft keeps parts from flying all over the place and maybe causing injury.
You aint kidding about the injury part...I popped the pitman arm off (both sides) with truck on ground using the standard cheapy pitman arm puller...worked like champ, but that sucker literally popped out. Scared me silly.
At 200k miles, the new pitman arm sure makes the steering feel tighter.
I believe it was from a head on collision 6months prior to.... the "PT Cruiser" went under my truck, we both we're going about 15-20 if not a little more, she ran a stop light as I was making a left, had my truck been lifted it would have been allot worse, I actually drove away from the accident and needless to say the PT Cruiser looked like a smart car..... (She was not hurt)
#28
WEAR SAFETY GLASSES or a FACE SHIELD when applying a great deal of torque to things under old trucks.
I had a puller and the pitman arm assembly fly 3 feet in the air when they let loose from an '85 Toyota steering box that I had clamped in my vise. Sounded like a gunshot and scared me half to death.
qmcdugan
07-18-2016 08:04 AM
