Help! Have codes
Old Apr 13, 2009 | 08:23 PM
chris491's Avatar
chris491
Help! Have codes
So it all started last night when driving home down the highway when engine died almost like i turned it off. No bucking or stuttering just died. Pulled over and started right up. No more problems for the night. Then today I start it up and it acts up ROMP ROMP ROMP then dies... does this 3 or 4 times and then fires up without a problem. Pulled these codes
P0006
P6A20
P6020
P6520
P27FE
Any help is greatly appreciated
Old Apr 13, 2009 | 08:41 PM
STROKER350's Avatar
STROKER350
chris491 you can do a search on the articles/specs on the bar up top. It lists all of the code numbers and what they are there. Hope this helps.
Old Apr 13, 2009 | 08:55 PM
rbaker6336's Avatar
rbaker6336
P0006 Fuel Shutoff Valve A Control Circuit Low
that's the only one I can find and don't it has to do with our trucks
Old Apr 13, 2009 | 09:00 PM
F350-6's Avatar
F350-6
What are you using to pull the codes? Most, if not all, of those don't make any sense. Sounds like you've got an electrical issue causing a short to ground. Check the wires going to the square box with a bolt in the middle of it on the drivers side valve cover. Either below or behind that box check for wires that have rubbed against any metal and worn the insulaiton down to the copper wires. You can also check the wires going to the IPR to make sure the insulation hasn't become brittle and is allowing those wires to short.
Old Apr 13, 2009 | 09:22 PM
chris491's Avatar
chris491
I pulled the codes with an old Hypermax programer. I will check the wires tomorrow since it is dark out now. I am suppose to take the truck in tomorrow to have some work done so I will probably let the mechanic take a look at it. Man im tired of spending money on this thing. Thanks for the help
Old Apr 13, 2009 | 10:18 PM
rbaker6336's Avatar
rbaker6336
That explains the goofy codes
Old Apr 13, 2009 | 11:28 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Be careful you don't get soaked. Those codes are out there. Reset them and see. The ones that return require attention. Anyone close to you? Stop going to shops unless you have to. That is why we are here.
tenaciousj
Sep 10, 2016 11:14 AM
JOHN2001
22
Jun 1, 2014 11:54 AM
1bad04
Dec 5, 2011 04:31 PM
74baja
33
Dec 28, 2009 01:01 PM
mudracin74
Feb 1, 2007 06:14 PM
