Easy way to gain HP on 1996 F150 5.0L
Old Apr 15, 2009 | 03:45 PM
FordFriend150's Avatar
FordFriend150
How long does the process of putting on headers usually take. If you dont mind, can i have name of a good headers manufacture company
Old Apr 15, 2009 | 04:15 PM
lew52's Avatar
lew52
I use headman elite headers...About 3 hrs if you dont have any problems with any bolts...That dosnt include exhaust work or how much beer you drink ??/ Lew
Old Apr 15, 2009 | 06:32 PM
FordFriend150
What about pace headers?
Old Apr 15, 2009 | 07:22 PM
jr32560's Avatar
jr32560
Originally Posted by 9.ford.5
yeah 1 problem with the i6 is they sound good in the LOW LOW rpms but once they clime it starts to sound ricey and i dont like that but talk to 6cylbill hes done a few different setup on the 6er and has sound clips
but for your v8 id say a set of longtube headers and either gut the cat and put a bigger tailpipe one it or you could buy the longtubes 2 hi-flo cats or another cheap one and gut them bothe then run true duals with some bigger pipe...as for mufflers...you have a v8 you dont need one
I hear conanski has a good set up for headers-I believe they go into one just before the cat-i want to see some pictures of it-well some good ones
Old Apr 15, 2009 | 07:25 PM
jr32560's Avatar
jr32560
if ya got the mid bed gas tank or aux. tank the true duals are a pain and not as effective as the should be-or so I have heard-my 78 e150 van was a pain in the well you know where-I was young and just had to have the duals-never again!never really saw any power or gas mileage increase either-but it sure did sound LOUD!!!
Old Apr 15, 2009 | 07:30 PM
1966Tbird's Avatar
1966Tbird
pace setter headers are terrible i won't let them be put onto any of the motors i build every set i have used has leaked either at the collector or at the flange where it bolts to the head, dynomax makes the easiest to fit headers and hooker makes the most hp but are the biggest pain in the *** to fit imho anyway
Old Apr 16, 2009 | 10:10 PM
FordFriend150
How much they running?
Old Sep 24, 2025 | 06:07 AM
95ford4's Avatar
95ford4
4wd Low
Originally Posted by 1994 F250: 351, C6
If it is one of those "cold air" kits that has a conical filter that sits under the hood in the open, take it back. All these setups do is suck in hot air from under the hood. The best way to modify the air intake on these trucks is to get the air intake tube off of a truck with a 300 or a 460 (they mount right up to your airbox) and get a reusable drop in filter. Since your truck is a '96 it has mass air, so if you get an oiled filter, be careful not to overoil the filter as it will dirty the mass air sensor. Honestly, the air intake is not much of a problem in these trucks, exhaust is the biggest problem.
Make sure the ignition system is tuned up good with new high quality spark plugs, wires, a cap, and rotor. I use Bosch plugs (a lot of people will tell you these are crap, but they have always been good to me) and Motorcraft wires, cap, and rotor. When tuning up the ignition make sure your base timing is set to 10 degrees btc, and you might be able to bump it to 12 or so, just make sure you don't get any detonation. This will give you better off-idle response.
Exhaust is where to go next. Mufflers, improve sound, but won't add any noticable power. Get a set of headers (if you get shorties, upgrade the y-pipe as well, the stock one is garbage), a high-flow cat (delete it if you don't have emmissions testing), a good performance muffler, and new pipe. Go with 2.5" pipe from the headers to where it merges in the y-pipe, and then run a 3" single the rest of the way out.
Next, if you are willing to get into some more complex stuff, get a cam. Get a good truck cam that has a power band starting no later than 1,500 RPM, preferably get one that starts at idle. Lumpy cams sound cool, but suck for trucks. Since you have mass air, you don't have to worry about any of the truck cams working with your computer.
After this, you get into the expensive stuff like heads, intake manifolds, etc.
Good luck with your truck and have fun!
what’s a good y pipe relacement? I’m likely doing a magna flow exhaust system and hedman shorty headers.
Old Sep 25, 2025 | 07:36 AM
HydroDog's Avatar
HydroDog
Hope your not looking for a reply from 1994 F250; his last post was 14 years ago.
2014coyote
5.0L Coyote
Sep 28, 2020 08:50 PM
evil-90
17
Sep 3, 2015 07:26 PM
cchimuk
21
Feb 23, 2013 03:33 AM
Gary Atsma
2009 - 2014 F150
Nov 8, 2010 12:34 AM
*keys*
39
Jun 5, 2008 10:39 PM
