low power
Old Jun 4, 2009 | 12:33 AM
  #61
Penrider's Avatar
Penrider
OK, sorry it took so long. Between work and a hundred other things I had to park the truck for a while.
I had the exhaust system replaced, that Helped.
I went by my other truck and totally re-installed all the EGR/Smog lines that were messed up or missing and replaced the EGR Valve, Big Improvement but it then had a dead spot in the throttle.
I took it to the local shop and the mechanic ran it down for me. It was Out of Time! Almost 15degrees retarded, why/how I don't know. It hadn't jumped time on the chain or anything, it was simply out of wack.
Now the dang truck runs like I think it should. Good first and second gears, ok third if it's tached-up, and 4th for highway only.
Thanks for all the suggestions,
Sean
Old Jun 4, 2009 | 07:38 AM
  #62
6CylBill's Avatar
6CylBill
Thanks for keeping us updated!!!
Old Jun 4, 2009 | 11:54 PM
  #63
flipklos's Avatar
flipklos
The cam was retarded? how the heck? By the way a 300 has a timing gear setup, no chain involved.
Old Jun 6, 2009 | 04:19 PM
  #64
Penrider's Avatar
Penrider
The man said it was out of time, so I assume the distributor was off. Either way, he got it straightened out. I don't know which timing setup it has, I haven't had to remove the front cover one one Yet.
comtb
Dec 27, 2014 03:45 AM
jt46321
Aug 3, 2014 10:21 PM
Shernius
1997 - 2003 F150
Oct 27, 2013 06:02 PM
HarrisonDawgs
Jul 16, 2008 01:12 AM
97f3504x4ps
Mar 6, 2008 05:06 PM
