"ZMax" Does anyone use it?
Old Apr 13, 2009 | 02:28 PM
ford2593's Avatar
ford2593
I have been seeing "ZMax" on the SPEED channel lately and heard the it can be used in diesels, does anyone use it, have any comments, or knows if there is another thread somewhere I can look?
Thanks
Old Apr 13, 2009 | 02:31 PM
UGA33's Avatar
UGA33
My uncle uses it in his equipment at his junk yard. They have a early 90's International rollback that hasn't had anything touched under the hood with a ton of miles on it and it gets a ZMax treatment once a year. I just know its expensive!
Old Apr 13, 2009 | 03:48 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
1 ton = 2000 lbs Does lbs equate to miles 1 for 1?
Old Apr 13, 2009 | 05:35 PM
UGA33's Avatar
UGA33
. No that is a unit of measurement we use in Cartersville, Ga to denote over 500k miles.
Old Apr 14, 2009 | 01:02 AM
ford2593's Avatar
ford2593
Originally Posted by bpofmd
1 ton = 2000 lbs does lbs equate to miles 1 for 1?
what?!!!!!
Old Apr 14, 2009 | 12:07 PM
JIM_C's Avatar
JIM_C
I've heard that. Over here in Tucker we say "a buncha" and down in Atlanta they say "ho lotta" - weird.
Old Apr 14, 2009 | 12:11 PM
ruffneck22's Avatar
ruffneck22
ive d it a couple times in the past with no negative side effects. dont know if i seen any kind of improvement but nothing bad for sure. A lot of people will tell you not to use additives with a 6.0PSD because they use oil pressure to fire your injectors but they claim that Zmax isnt an additive but a micro-lubricant so as long as it meets specs then its good i think
Old Apr 14, 2009 | 12:21 PM
ruffneck22's Avatar
ruffneck22
heres a link for you to check out.
zMax | Technical
Old Apr 14, 2009 | 01:44 PM
dchamberlain's Avatar
dchamberlain
And here is a good reason not to use it, IMO.
According to the FTC, the CRC L38 test is a standard auto industry tool to measure the bearing corrosion protection properties of motor oils. In February/March 1997, an independent laboratory performed two CRC L38 tests of zMax for Speedway and Oil Chem. In those tests, motor oil treated with zMax produced more than twice as much bearing corrosion as motor oil alone.
FTC Sues Speedway Motorsports and Oil-Chem Subsidiary
Old Apr 14, 2009 | 07:40 PM
ingman's Avatar
ingman
I have been told not use additives with solids (teflon).
I have heard that duraLube is ok no solids or ash.
Good luck
Doo Dah
Sep 14, 2016 03:46 PM
Mtnhermit
Apr 30, 2016 12:57 AM
AXracer
20
Sep 20, 2015 03:12 PM
FORDMANMATT
Feb 20, 2014 12:48 PM
Mikeymikef
Aug 6, 2011 12:43 PM
