Seafoam
Old Apr 14, 2009 | 07:47 PM
WAExplorer's Avatar
WAExplorer
At this point, It couldn't hurt
Old Apr 14, 2009 | 08:24 PM
dirtballer's Avatar
dirtballer
Yeh i will give it a try i need the truck just to pull my 5th wheel from las vegas,nv to elko,nv its about 500 miles i think the ford will make it.
Old Apr 14, 2009 | 09:19 PM
hittman1422's Avatar
hittman1422
oh yeah it SHOULD make it, dont quote me but if i had no other truck to take i wouldent worry, might murder your mileage and cut down on your power... and it'd be a good idea to check oil often.... but you already know that. let us know how that works out!
Old Apr 14, 2009 | 10:21 PM
dirtballer's Avatar
dirtballer
I have already put about 100 miles on it and it doest seam to be burn oil and i havent had any other problems knock on wood i"ll but some lucas and hope it helps the mileage sucks 8 to 10 gallons to about 50 miles god i love my 300ci 4 speed ha ha
Old Apr 14, 2009 | 10:29 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Welp, All the rage made me break down and try this SeaFoam stuff, I don't generally buy "Wonder Juices", but it's seems like every other word on 99.9% of the threads here are SeaFoam...
I will do about half a fuel filter and see how it goes!
Never learn if you don't try something!
-Enjoy
fh : )_~
Old Apr 14, 2009 | 11:54 PM
Sycostang67's Avatar
Sycostang67
I run 10-40 and a bottle of lucas. It clears up the smoke caused by the bad rings, but I still get a puff when I start it. I'd just try adding the lucas first, running 20-50 is pretty hard on a motor. I ran 20-50 in my 300 to slow the oil leakeage. It caused it to crank over so slow in the winter that I thought it wasn't gonna start at all. Man I can't wait to get my new motor dropped in.
Old Apr 15, 2009 | 12:35 AM
dirtballer's Avatar
dirtballer
Do you run normal oil level plus the lucas ?
Old Apr 15, 2009 | 01:08 AM
hittman1422
wow i use 5w-30, talk about a lightweight....
Old Apr 15, 2009 | 01:26 AM
dirtballer's Avatar
dirtballer
I live were it get around 120 degrees in the summer so i run 10/40 and change my oil every 2 or 3 weeks
Old Apr 15, 2009 | 01:53 PM
Freaksh0w's Avatar
Freaksh0w
I wouldn't run the Lucas. No, I don't think it would hurt anything. I just know it won't help anything. I'd try a stop leak type fluid first. I've actually seen those 'stop leaks'. Now, that won't last forever, but it's better than Lucas. Lucas has NO additives in it. And it makes your oil like a 30W-80 when you mix it with 10W-30. I used to love it until I got some VOA's of it. Literally nothing is in it that shows up in an oil analysis. It has a low flash point and is very thick. It just dilutes the add pack of the oil you choose.
So, I'd probably use some Bars stop leak, maybe? Put it in a smoking, leaking Honda before and it completely stopped the leaking/smoking for about 2-3 weeks at a time, lol. Maybe you will have better luck with it.
Bar's Leaks Engine Oil Stop Leak
That's what I'd use. I don't think the stuff I used was name brand. I didn't even pick it out, but the car was a P.O.S., so I had no problem putting it in there for her, lol. I know the Bar's brand says it conditions seals, so it COULD be a little fix up. Nothing like a rebuild, but better than smoking like crazy.
Old Apr 15, 2009 | 03:38 PM
Festus Hagen
Methanoholic
Ok, pulled my filter and filled it with SeaFoam ... Nothing changed! Nadda!
No smoke, No nothing, Ran like normal, No better, No worse.
(Doesn't run bad anyways)
I expected it to at least smoke.
Stuff smells like it's got Alcohol in it.
-Enjoy
fh : )_~
Old Apr 15, 2009 | 03:42 PM
86bigred's Avatar
86bigred
-Enjoy
fh : )_~
which filter?? oil, fuel
Old Apr 15, 2009 | 03:52 PM
  #28
Festus Hagen
Methanoholic
Yea, I guess that should of been included ... Duh!
Fuel.
-Enjoy
fh : )_~
Old Apr 15, 2009 | 04:06 PM
  #29
86bigred's Avatar
86bigred
both of your are diesel"s are they not.i use seafoam on gas engines. howe's diesel treat in my diesel's when i had one.don't know how good seafoam. would be on your injectors
Old Apr 15, 2009 | 05:05 PM
  #30
Festus Hagen
Methanoholic
Yup, They are...
SeaFoam is for Diesels as well.
I'll stick with KD100d for my fuel treatments.
-Enjoy
fh : )_~
