Turbo Compressor Wheel Movement?
Old Apr 12, 2009 | 07:52 PM
countrykid_86's Avatar
countrykid_86
I am finally getting around to putting bellowed up-pipes on. Just got the turbo off and started looking it over. The compressor wheel has the slightest amount of side to side play. I thought this was normal, but i thought I would ask you guys. My 02 F-250 only has 88,000 on it. Does this sound normal or should there be no side to side play at all?
Old Apr 12, 2009 | 07:56 PM
PaysonPSD's Avatar
PaysonPSD
That type of play is normal. In and out would be bad. When running the play you feel will be gone do to oil pressure on the bearing.
Old Apr 12, 2009 | 08:09 PM
Ziggy.'s Avatar
Ziggy.
Just like Robin said, side to side is typical, only aslong as the wheel doesnt contact the housing you are good to go. There shouldnt be any front to back play.
Old Apr 12, 2009 | 08:10 PM
countrykid_86
Okay Thanks
