Power window
Old Apr 12, 2009 | 11:44 AM
GA_Boy's Avatar
GA_Boy
Power window
2001 F250 7.3, 6 spd
I was away for 6 weeks and the truck wasn't moved/cranked.
I came back home and it started up fine but the Passenger side window will not operate from either switch. As far as I can tell everything else is OK.
Any help is appreciated.
Marvin
Old Apr 12, 2009 | 12:51 PM
greedy737's Avatar
greedy737
I'll give you a bump!
Old Apr 12, 2009 | 01:00 PM
Quick444's Avatar
Quick444
I would assume the switch either died or the motor crapped out on your.
Not sure how to diagnose either though.
Old Apr 12, 2009 | 01:25 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
I have had the same problem with all 4 windows. I play with the window lock rocker switch and keep things clean and no more problems. I'm sure I will be replacing parts before too long. But it's working for now.
My back windows will lock up on hot days. After driving for about 10 minutes the glass cools down and the windows go back up.
Old Apr 12, 2009 | 01:27 PM
GA_Boy's Avatar
GA_Boy
Thanks, I figured that both windows were on the same fuse so I didn't check fuses. I had that door panel off last year when I made to door lock repair. I got the door lock info from this forum and it was great info.
Marvin
Quick444's Avatar
Quick444
In your case it sounds like the entire unit went out/is going out.
Old Apr 12, 2009 | 01:28 PM
Quick444's Avatar
Quick444
Marvin
I intend to be doing that fix in the near future myself.
Old Apr 13, 2009 | 10:08 AM
GA_Boy's Avatar
GA_Boy
Thanks, by entire unit do you mean the motor? Since it sat for about 6 weeks could corrosion be a problem and if so where do I start.
Basically, I just don't know where to start with my troubleshooting. I know first to chek power and after that I'm lost.
Marvin
Old Apr 13, 2009 | 10:42 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
This is how to take the panel off to get to things in the door. click here
Old Apr 14, 2009 | 03:04 PM
Quick444's Avatar
Quick444
Well my guess is that if both of your back windows stop working at the same time, it would be more likely that the switch is crapping out than both motors at the exact same time.
I would start with the switch and if that doesn't fix it then it might be the wiring or the motors.
Hopefully some other people chime in so I don't steer you in the wrong direction.
Old Apr 14, 2009 | 03:54 PM
PaysonPSD's Avatar
PaysonPSD
Pop out the button panel on the passenger side and reseat the connector for the window switch a few times. If that doesn't help try the driver side. There is a common wire that runs between the to switches and a connector may be dirty or loose. Certainly worth a try and only takes a few minutes.
Old Apr 14, 2009 | 04:21 PM
4EXTRDR's Avatar
4EXTRDR
Happened to me...I will tell you my scientific diagnosis method... I held the switch down and lightly punched the door (on the inside of the truck) roughly where the motor was. After a short "burst of life" from the window (ruled out the switch)...I replaced the motor and track assembly (comes as one unit from Ferd)...was fairly easy to do. High-Tech huh?
Old Apr 14, 2009 | 06:29 PM
big poppa's Avatar
big poppa
Hey Marvin, if you check out what everybody above said to check out and its shot, go here https://www.ford-trucks.com/forums/8...ct-w-pics.html Ryan is parting out a truck and he might be able to help you..
Old Apr 14, 2009 | 08:27 PM
danskool's Avatar
danskool
Go Bills !
In Ricks post. Door panel removal
Shows you the underside of the switches and connectors
You can pop out the the little switch section in 5 seconds. Then unhook the connectors and measure voltages as per this .pdf. according to you connector configuration.
See if your getting power were your supposed to.
What i found interesting was this:
• All Power Windows Are Inoperative
• Fuse or circuit breakers.
• Circuit(s).
• LF window control switch. <---- under all windows inoperative.. LF ?
• Junction box fuse/relay
panel.
File Type: pdf
Old Apr 14, 2009 | 10:27 PM
JockD's Avatar
JockD
The passenger window grounds through the driver's window switch. The crew cab switches are different from the regular and extended cab models, but work the same way.
You can take the switches apart, if you are careful, by prying loose the snaps. You can then clean up the corroded contact points, etc.
You can get the window motor by itself from aftermarket sources. The regulator and channels are very reliable, but need to be lubricated now and then.
