A4LD Vacuum Modulator Replacement
Old Dec 30, 2002 | 05:54 PM
parisotrs's Avatar
parisotrs
Hi All,
I have a 91' Explorer, and am experiencing a slip between 1st and 2nd.
It started when I replaced the vacuum modulator several years ago. I guess my question is, how many pins are there supposed to be. Just one, larger pin? Or does a smaller slide into the modulator, and fit into the larger pin that slides into the transmisson?
Thanks in advance!
Robert
Old Dec 30, 2002 | 06:23 PM
Opera House Works's Avatar
Opera House Works
There is only one pin. This is inconvenient to work on. The aluminum piston valve in the transmission body can get stuck from dirt. When you replaced the modulator was there oil in the vacuum side? Did the replacement solve any problem? The reason I ask is that your problem could be a sticking speed governor in the extension housing or a couple of other things. Do you have a delayed reverse engagement too?
Old Dec 30, 2002 | 07:21 PM
parisotrs's Avatar
parisotrs
Well, my friend seems to have solved the problem! There was no pin that went into the modulator, there was only the aluminum piston valve, which I was mistaking for "the pin". When the modulator was replaced several years ago, due to tranny fluid being sucked up and into the intake, the pin that goes into the modulator obviously became lost. The guy that originaly replaced the modulator must not have noticed the pin missing, and I surely had no idea what was looking for. It seems to be shifing fine now.
Thanks for the reply!
Robert
Old Jan 1, 2003 | 08:22 PM
first time 4x4's Avatar
first time 4x4
Old Jun 23, 2011 | 02:32 PM
ghost_9290's Avatar
ghost_9290
I took out my modulator and the metal pin was not there. Does anyone know where I can get a new one so my truck will shift properly?
Old Jun 23, 2011 | 03:34 PM
Lazy K's Avatar
Lazy K
https://www.wittrans.com/Schematic.a...5E&Schematic=4 Click on this link and then on part 164.
Old Jun 27, 2011 | 10:35 AM
ghost_9290's Avatar
ghost_9290
YES! Thanks so much Lazy K!
gwshaw
1983 - 2012 Ranger & B-Series
Dec 10, 2016 09:14 PM
kyle j
Apr 23, 2016 05:44 AM
Brnfree
Mar 29, 2014 11:42 PM
nlareau
Jun 16, 2011 06:10 PM
PSNut
Oct 18, 2009 04:31 PM
