Gear vendors od?
Old Apr 11, 2009 | 12:08 PM
orng1's Avatar
orng1
Gear vendors od?
A friend called me up yesterday with a stalling truck. They were on the freeway and it stalled out while driving, it'd start up but stall all the time. I told him to try and replace the cps. It idled well but coudn't drive at all, as soon as you put it in drive it stalls. We thought maybe the converter had stuck or something so I told him to try and give it some gas when shifting it so it won't stall. Well that worked but now it's not moving.
We keep diagnosing it and we get to a Gear vendors overdrive unit, there is oil all over it. Disconnect the solenoid, and tried driving it and now it moves. It seems like the truck has no power. It's like maybe the TC is slipping to much.
Has anyone had any problems like this? I think maybe the unit is fried. Any suggestions?
Old Apr 11, 2009 | 01:58 PM
Quick444's Avatar
Quick444
No idea on this one, but thought I would give ya a bump.
Old Apr 11, 2009 | 03:02 PM
orng1's Avatar
orng1
Thanks, so here's what we got so far. H changed the oil in that od gear deal and filled it from the wrong hole. Don't ask me I haven't even seen it. Well there was only about 1/4 quart in there and it seems that he burned it up. We're going to look for a regular driveshaft and get rid of that gearvendor's od deal.
So anyone happen to have one laying around they'd like to donate?
It's a cc sb srw.
Old Apr 11, 2009 | 06:20 PM
F350-6's Avatar
F350-6
Not too many of us keep one of those laying around on the shelf. I take it this truck is fairly new to him? Did he ever use the GV unit? If it's something he likes, you might contact them about the cost to rebuild the unit.
Old Apr 11, 2009 | 08:27 PM
bfife's Avatar
bfife
still plays with trucks
GV will typically offer a reduced price for return customers,ie: repairs etc. and yeh if he ran it low on fluid, its toast. they normally hold 2 quarts of a GM's special oil. I don't recall the part # but thats all they reccommend. Barney
Old Apr 11, 2009 | 09:21 PM
orng1's Avatar
orng1
The synchromesh stuff?
Their just afraid that it's going to cost a lot. So where can I got ahold of them?
Old Apr 11, 2009 | 09:26 PM
orng1's Avatar
orng1
He got it with it about a yr ago, it also had a banks tuner on it.
Old Apr 11, 2009 | 11:46 PM
bfife's Avatar
bfife
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
they are based in Ca
and yes they are about $3000.00
Barney
Old Apr 12, 2009 | 09:26 AM
orng1's Avatar
orng1
$3k
Ok so anyone have a stock driveshaft they aren't using?
Old Apr 12, 2009 | 10:15 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by orng1
$3k
Tried a local junkyard?
