try the pickup screen in the tank, that happened to me on my 6.5L just plugged, now it runs again.... (DSG said it was Injection pump and injectors and lift pump.... $4500 down the drain....)
He's already tried that, he cleaned all the intank parts, and replaced/ cleaned all the lines. I heard his pump on the phone when we talked the other day and I am pretty sure the fuel pump is the culprit.
I have been having a similar problem with my '01 7.3, however my problems don't occur unless have been trveling 75+ for 20 - 30 minutes, or towing trailer at 60+ for awhile. Everything else sounds just like it: feels like lack of fuel, loses power, runs really rough, until shutoff or idles for 10 minutes or so. I had been reading this thread hoping for the ansswer, but looks like Bama is on a sabbatical.
In the meantime I checkec out a site called www.justanswer.com and got some more info from a guy there. He quoted a mechanic from some site (/uploads/Cwilson83/2009-05-02_081613_post.png).
In that case the truck would die after 5 minutes and recover after sitting for 5 minutes. He said the ICP fuel reg never drops below 55psi, pulled and cleaned the tank, cleaned filter housing, rail and injectors - SAME Problem. New fuel pump- SAME. new pressure valves in heads - SAME. Previous shops had replaced ECU, Pressure Regulator, and ICP Regulator.
Long story short, he found the sending unit in the Bypass System plugged up - "That's what them little plastic squares are on sending unit! Installed new sending unit and ---"
Now I've got to find the sending unit.......
Welcome to FTE.
You can dissassemble the mixing chamber and clean out those screens.
You don't need to buy a new pickup assembly.
Welcome to FTE.
Probably a stupid question, but can a "saturday-afternoon mechanic" do this? Is there a diagram I can get of where and what to remove? I know if I go to a dealer they are going to want to sell me as much as they can.
I know which end of a wrench to hold, but I need a picture. Can you help?
