It reminds me that my 4wd system started to stay locked at the wrong times a couple years ago, and I've been driving around with the control module disconnected. I thought it might have been uneven tire wear, as it started right after I did a front-rear tire rotation. I'm not worried about a leaky or otherwise defective sensor that is nearly impossible to replace. Have to check this weekend.
One of my speed sensors on the transfer case is leaking through the sensor and out of the prongs, so it is almost toast. Sense I had the day off I would see if I could get a replacement. To my dismay to find out, Ford Discontinued it, 2/15/09
Nothing on D2D.
Checked with aftermarket sources, they all say dealer only part.
So how can Ford discontinue a vital part like this?
So if anyone has a spare new one/slightly used in their collection or knows where I might be able to locate one, I would be greatly appreciative.
