CCV mod final decision
Old Apr 13, 2009 | 11:59 AM
Izzy351's Avatar
Izzy351
Nice kit, Dave!
Old Apr 13, 2009 | 12:19 PM
aklim's Avatar
aklim
Originally Posted by Pocket
If you vent to atmosphere, you'll have no problem venting straight down behind the engine or routing the hose over the master cylinder. I've had my CCV mod for 4 years now, and it's always been routed over the master cylinder. No oil pools up in the CCV hose, it simply drains back into the valve cover.
I saw the CCV mod as the way that International does it per their parts manual. Just a straight pipe to the back of the VC and down the block.
Old Apr 13, 2009 | 07:28 PM
ernesteugene's Avatar
ernesteugene
Originally Posted by dave at BD Power
...a kit that does not vent to atmosphere, comes with a filter and a bypass that opens at 1 PSI and looks like a factory install...
This statement "seems" to imply that your kit allows the crankcase pressure to increase to 1 psi=27.68" H2O before a "bypass" opens to limit any further increase in crankcase pressure???
A 1 psi crankcase pressure is what I measured in trucks that had their CCV hose routed to their tailpipe and that's far too high a pressure for the crankcase. Under WOT full load the crankcase pressure of a healthy engine with the CCV vented directly to the atmosphere shouldn't exceed 4" H2O=0.145 psi and the OEM Ford design provides a 2" H2O to 6" H2O vacuum in the crankcase depending on engine load where the higher vacuum occurs at higher loads where it's needed to vent the increased blow by.
Here's some pictures of how I instrumented my old F350 to measure the crankcase pressure so I could keep tabs on the CCV hose and on the blow by in general especially when towing long steep grades at WOT. Basically you install a fitting for a 1/4" ID plastic hose on the oil filler neck and run the hose to a 10" H2O gauge in the cockpit. In the picture below the gauge on the left which reads from 0" to 10" H2O...
...was connected to the hose going to the oil filler tube in this picture...
With my CCV design I had a crankcase pressure of 0.7" H20 at idle and 3.0" H20 at WOT full load which indicates that my rings were sealing well. A new engine exhibits about a x4 increase in crankcase pressure from idle to WOT full load.
Using a gauge with a 10" H2O scale allows for some needle bounce which you'll get under some load conditions and for increased readings due to engine wear. An older engine nearing the end of its service life exhibits higher crankcase pressures at all throttle positions and about a x8 increase in crankcase pressure from idle to WOT full load.
A crankcase pressure gauge is a good way of monitoring the general health status of your engine and I especially recommend it for anyone who's attempting to improve on Ford's vacuum regulator design by routing a catch canister back into the intake as well as for anyone running their CCV hose through a catch canister that vents to the atmosphere. Here is a link to where I bought of the 10" H2O gauge shown in the picture...
Phone (609) 259-8900 Fax (609) 259-3575 Internet:McMaster-Carr
E-mail:nj.sales@mcmaster.com
Each 4026K251 Low-Pressure Diaphragm Gauge 1.5% Accuracy, 1/4" NPT Center Back, 0-10" of H2O (Same as 4026K5) $49.65 $49.65 Monday morning
Old Apr 13, 2009 | 08:02 PM
PeterAL's Avatar
PeterAL
Hmmm, do I understand you correctly that with a CCV hose routed to the tailpipe, but NOT into the tailpipe, you got that high a cankcase pressure?
That would be an open hose running from front to back end, and exiting somewhere near the end of the exhaust pipe. Or are you referring to those systems that have the hose connected to a fitting that dumps INTO the exhaust pipe?
Thanks for your detailed replies on this issue.
Old Apr 13, 2009 | 08:14 PM
shark1979's Avatar
shark1979
now i am confused should you do the ccv mod or not? for the reason if you do the ccv mod you will not have a negtive pressure in the crankcase. do you wnat a negtive or not???? to many choices
Old Apr 13, 2009 | 08:18 PM
PeterAL's Avatar
PeterAL
Exactly shark.. that's why I started this thread..
There seems to me to be a couple of conflicting opinions...
1. Route the hose over the brake controller, or directly down.
2. Use a filter/trap or not.
And, there doesn't seem to be consensus.
I don't want a lot of stinky smoke and I don't want to continue to pollute my engine. And of course, I don;t want to harm my engine.
Old Apr 13, 2009 | 08:23 PM
shark1979's Avatar
shark1979
i got all the stuff to do but not sure that i should now. cause i understand point of the negtive pressure in the crankcase. but also understand why i dont want all the oil resdue air going through my turbo and intercooler. NEED HELP!!
Old Apr 13, 2009 | 08:54 PM
Fat Diesel's Avatar
Fat Diesel
He's talking about hooking it directly into the exhaust stream, like I did over a 125,000 miles ago. Apparently my engine is more durable than most since it's still fine after all these high pressure miles and years. I take my truck past 3000 rpm at WOT every day of it's life and it's still a champ. I've got plenty of blow-by, probably more than most, and despite all these pressures building and building in my crankcase I still haven't blown a gasket or even popped the dipstick out of the tube! I've got nearly 250,000 miles on it and when the day comes to put a new engine in, it will get the same CCV system!
But seriously folks, there is clearly not a consensus on whether it is bad to hook it to your exhaust. I'm just showing you that there are trucks out there with it run to the exhaust without having any problems at all.
Here's a pic that shows how I did it...
Old Apr 13, 2009 | 10:41 PM
JockD's Avatar
JockD
Andy, you have a 4" exhaust. It looks like the CCV enters the exhaust just ahead of the rear axle. Is that a muffler or resonator just upstream of the entry point? The restriction of a muffler may make a big difference in the pressure in the exhaust stream. It looks like your CCV enters the exhaust at nearly a 90* angle. Is that correct?
Old Apr 14, 2009 | 09:39 AM
superduty4x4's Avatar
superduty4x4
Do the CCV mod, if nothing else it keeps the oil out of your intercooler and all over your engine/CAC pipes. How you do it is totally up to you... tons of options as you already know.
Old Apr 14, 2009 | 11:12 AM
Fat Diesel's Avatar
Fat Diesel
That is a muffler. It's a BD one from about 8 years ago or so. You can see through it, there's a propeller shaped baffle of some sort in there. The connection point is just before the axle. I think it's closer to 45* than 90* though. I just mounted it that way to make it easier to run the hose! Gene, I know you cringe when you read this stuff!
Someday I'll pull the valve cover and we'll see if all that corrosive gas is just eating my engine away from the doghouse down. Based on my very own extensive bar stool analysis, if it really is very corrosive it would chew it's way through the IC in the OEM configuration.
Old Apr 14, 2009 | 03:26 PM
ernesteugene
Originally Posted by PeterAL
...There seems to me to be a couple of conflicting opinions...
I don't want a lot of stinky smoke and I don't want to continue to pollute my engine. And of course, I don;t want to harm my engine...
1. Thanks to "gravity" when you run the CCV hose up and over the master cylinder the oil vapor which condenses in that run of CCV hose drains back into the doghouse and when the engine is running this helps to reduce the amount of "stinky" oil vapor coming out of the end of your CCV hose and after you park it reduces the oil drips in your driveway.
However if you use this approach the entire time your engine is running some oil vapor is continuously condensing and draining back into the doghouse and for the reasons I've already stated I'd rather put up with more vapor and more drips from my CCV hose than to let that "nasty acidic condensation" continuously drain back into my engine!
The OEM Ford design doesn't allow condensed oil vapor to drain back into the engine because the Ford design is continuously sucking it out, however it's then depositing it in the intake to the turbo which leads to a different set of issues such as blown CAC boots and oil accumulation in the intercooler.
2. Those who employ a "filter/trap" usually run the CCV hose up and over the master cylinder and then down to a "filter/trap" that's near the warmth of the engine and then out to the rear of the truck and this configuration dramatically reduces the stink but does so at the expense of increasing crankcase pressure.
When it comes to the CCV mod there's no free lunch and stinky fumes and a dripping CCV hose are what you need to accept if you want to minimize your crankcase pressure when your engine is under a maximum load and producing its maximum amount of blow by.
Old Apr 14, 2009 | 04:38 PM
  #28
smoky_diesel's Avatar
smoky_diesel
When it comes to the CCV mod there's no free lunch and stinky fumes and a dripping CCV hose are what you need to accept if you want to minimize your crankcase pressure...
I'd rather clean the boots once a year that fill my cab with stinky smoke. I put mine back to stock. didn't see any performance gain.
Old Apr 14, 2009 | 04:42 PM
  #29
aklim's Avatar
aklim
But you might see a performance loss if the boots slip out.
Old Apr 14, 2009 | 04:49 PM
  #30
ernesteugene
Originally Posted by Fat Diesel
...But seriously folks, there is clearly not a consensus on whether it is bad to hook it to your exhaust...
...Ernest knows all too well that I haven't always agreed with him in the past, but in this case, I do agree that the CCV in the exhaust doesn't work. Every person that has tested the way he is suggesting has always ended up with additional pressure in the crankcase when the CCV is routed into the exhaust...
CCV into exhaust.
https://www.ford-trucks.com/forums/7...o-exhaust.html
Originally Posted by bfife
Don't do it!! I did and now I don't. I argued with Eugene repeatedly about this. (Damn engineers think they know everything LOL) I used a check valve and a venturi tube, did everything right. I have been fighting a valve cover oil leak for almost a year, resealed twice, new gasket, proper torque, locktight, you name it I tried it. Finally I diconnected the CCV mod from the exhuast and the leak stopped. Just save yourself the hassle. Don't install the Mod into the exhaust. Barney
Originally Posted by Izzy351
Gene proved that it *does* happen by measuring *POSITIVE* CC pressure at the oil cap on several trucks. It's not a theory, it's been proven. I was going to do it as well, but not after seeing that discussion. IIRC, it *can* work with a gasser because the exhaust pulses are undisturbed as they traverse the exhaust pipe. After pushing through a turbo, they're no longer distinct pulses -- just high pressure flow that wants to push back up the "venturi" that really isn't.
Originally Posted by jtharvey
I have also tested a positive pressure from the actual tube in the exhaust, not just the oil filler cap. I hooked up Gene's gauge directly to the tube I had running into the exhaust. When I saw positive pressure, the CCV never went back into the exhaust.
Originally Posted by miller_feed
Gene has proof that putting the CCV to the exhaust will cause back psi and will start blowing seals. I don't know for sure about this because I have not done the CCV mod.
CCV mod into exhaust?
A number of us have tried it, including me, but have since removed it. I put a pressure gauge on the tube that I had running into the exhaust, like you described it with the bung in the direction of the flow, and it actually was not providing a suction, but giving pressure. If hooked up to the CCV, this would pressurize your crankcase, which is a bad thing. The general concensus is to stay with a free flowing tube that just vents to the atmosphere.
If you put a pressure gauge on your oil cap & measure a lot of pressure with it hooked up, and not as much with it vented, I'd consider that "seeing for yourself". I didn't have to -- I took the good word of Gene and several of the others that had theirs measured. Extra pressure in your CC is a bad, BAD thing...
